Question about Rowenta Irons
My brand new Rowenta 9240 top of the range steam iron - being used for the very first time has an annoying throb on all steam settings.[audible at times]
Posted by Bona Fide on
ray gallant
    Top Expert:
  • Rowenta Master
  • 69,327 Answers
Live with it we have no idea since they developed wash and wear who irons any thing
Posted on Jul 25, 2020
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
My Steam Iron Rowenta dx1700 leaks on my clothes and turns itself off while I am ironong. I am ready to chuck it.
My brand new DX1700 iron leaks. Why is it leaking. I had a Rowenta Professional for 17 years and it never leaked. What do I need to do.
Jan 12, 2011 | Rowenta Perfect Iron
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
I need to use the self clean on my Rowenta professional iron
On the Rowenta DX8750 Professional model you fill the water tank, set on high, and HOLD the steam level lever all the way over to the right (where it says "self clean"). I did not see the info on the internet anywhere (not even in an online manual I found - my husband pointed it out to me.
You have to hold the lever over the entire time, it won't stay in that position so you almost have to use two hands. Pick the iron up hold it as you would ironing and rock it back and forth bottom to top. It's good to have a cloth under the iron so the yucky stuff doesn't get on your ironing board. I rocked it, and then would lift it nearly vertical and flakes of yuck would come out in the steam, and browinish yucky stuff would come out of the steam holes - just clean that off the sole plate when cool.
Feb 14, 2010 | Rowenta Irons
My iron rowenta leaks when before and after i!m iroeing
my iron is different to yours but i used to have leaks as well.
for me it was because i have a heat setting dial that indicates that the steam function is activated when set to a very high temperature.
i also have a push lever on the top of the iron that controls how much, if any, steam is produced by the iron.
the amount of steam is regulated by letting more or less water through to be vaporised by the heating element.
if the heat setting is low and the steam setting has not been switched off then water is being allowed through but the element is not hot enough to vaporise the water. the result is water pooling and either dribbling through onto the clothing you are ironing or running off when you sit the iron up.
maybe it will help if you turn the steam setting off while the iron is not in use.
Jan 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Rowenta iron
Dropping any iron is the kiss of death... dont use it again, especially on the steam setting.. you could electrocute yourself..
Dispose of it safely and get a new one. You wont make that mistake again in a hurry... I didnt!
:o)
Aug 03, 2008 | Rowenta DZ1700 Iron
Irons Logo
21 people viewed this question
Top Rowenta Irons Experts
Bruce Showalter
Colin Stickland
Colin Stickland
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
