Question about Sony Audio Players & Recorders
Why does my Sony b.t. model # srs-xb20 power off when it's at high volume when a song starts?
Posted by Billy Gideon on
Anon
  • Sony Master
  • 1,495 Answers
Assuming you are using a cable to connect your cell phone to the speaker you could be overloading the input of the speaker when you turn the phone volume up very high. That would cause distortion that might damage the speaker so it shuts down or turns off.
Posted on Jul 25, 2020
No audio to internal speakers,audio out to amp is good.
THIS AUDIO PROBLEM PERTAINS A FEW DIFFERENT NAME BRANDS AND TO MOST VIZIO Tv MODELS
MADE IN THE LAST 2-3 YEARS MAYBE EVEN 4+ I'M NOT SURE
WHEN IT STARTED.
I do believe your model is equipped with the SRS features which IS a formatted audio enhancement . Anyway go into the advanced audio settings in Tv's menu and TURN OFF the SRS tru volume leveling & the SRS tru surround feature. Additionally in the Tv's menu also has an option to turn off the internal speakers. And another common pitfall that I see happening to people. Is check the PCM and or LPCM option in both your Tv & your cable/satellite box's audio menu setup/settings. LPCM is Limited Digital Audio and PCM is Variable Digital Audio (VOLUME AMPLIFICATION) but
because it is a digital signal the two formats conflict, and the audio
will in and out.
WHEN IT STARTED.
P.S. YOUR WELCOME I SAY THAT CAUSE QUITE OFTEN IT IS
THE AUDIO PROBLEM VIZIO CUSTOMERS ARE HAVING!!!
Jason Draimen AKA "AVALANCHE" !!!
Apr 01, 2013 | Vizio VF550M 55 in. LCD HDTV
The sony lbt-xb20 is not a console, its a compact hifi stereo system ive cleaned the laser but still comes up no disc its a 5 cd changer
You should examine the carriage that mounts the laser/lens, make certain it can move. You should also try cleaning it with Servisol video 40 or lens cleaning fluid if you have not done this allready. Looking a the lens with a magnifying glass might reveal damage to it.
The model number of the lens unit should be on it. It might start with the letters KSS.
If you don need a new one then I have to tell you it won't be cheap.
Jan 28, 2013 | Audio Players & Recorders
My sony -G502 phone's volume up & down keys are not working..How can i increase volume while playing song or video?? Please help..
Get a suitable headset with remote, and then you can increase the Volume of the song and then remove the headset to activate loudspeakers.
Jul 18, 2011 | Sony Ericsson G502 Cellular Phone
Firrst what is an srs WOW mode i downloaded songs and they only play 4 10 secs and then another song starts and it does the same thing?
what is the motherboard? also it sounds like its set up on like auto scan each song for a few seconds then change.
srs wow mode imakes it sound lik a virtual surround sound systm i would disable that and try the songs again. also try using winamp instead of itunes or windows media
Mar 17, 2011 | Computers & Internet
MY SONY YARI U100I KEYS ARE NOT WORKING
my yari phone is 6months only, and it gives alot of problem like when the song is playing suddenly the volume decreases and the song track changes moreover i cant listen to a song properly because the volume button has got a problem and it gives alot a trouble.
Dec 16, 2010 | Sony Ericsson Yari Cell Phone
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
Projector powers down and re starts over and over
the colorwheel, the ballast, or the power supply are not working properly.
Apr 16, 2009 | Eiki LC-XB20 Projector Multimedia...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
SOUND/VOLUME PROBLEM!
It may be a problem with you headphones. Also make sure Sound Check is turned off!
Aug 05, 2008 | Apple iPod nano
Less sound
go to media player and open equalizer and select manual then edit and move upwards all the graphs and add the songs with high bitrate.
Nov 27, 2007 | Sony Ericsson K750i Cellular Phone
26 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
