Question about Home
Hello everyone is somebody there can help me find a part for my moorefield rain shower its leaking and I tried to fixed it and looking for the function cartridge Bought the unit at Loes but not selling parts. Thanks Raul
Posted by Raul Enriquez on
Andrew Taylor
    Top Expert:
  • Home Master
  • 34,068 Answers
Review on it
??????????1 out of 5 stars. · 2 months ago
non-existent customer service
A plumber installed this in our new house and there was no hot water. He checked the supply lines and they are fine. The bath and sink are fine, so it is just the shower that is the problem. There is no answer or call back from Moorefield, no response from Lowe's, no FAQs or trouble-shooting, nor any way to get cartridges, nor any support whatsoever. Ridiculous.
I would take the cartridge apart and hope it is just a worn o-ring. Buy some water pump grease and reassemble with new o-rings. It does appear to be a Lowes brand, so they should support it. I would phone head office.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk03M1PGDpEdQX2mVQGhYcYf9i7oTEQ%3A1595612820729&ei=lB4bX7iBLIqLytMPjpOK4As&q=moorefield+rain+shower
Posted on Jul 24, 2020
What should I do to fix this problem?
Then you have a leak, as to the location that is difficult to say without leak testing under a special rain shower simulator.
May 09, 2016 | Seat Cars & Trucks
Water leaks shere showerhead joins the shower stem
when reconnecting the shower head to the pipe coming from the wall..
did you use some pipe tape, pro dope or another type of joining compound?
this seems likely to be the problem.. if you don't have any on hand, visit a hardware store and ask their staff for pipe tape for plumbing and you should be pointed into the right direction.
May 12, 2010 | Water Pik & Wallmount Showerhead
The weight of the arm and rain head is too heavy for fixing
can you at all shorten the length of the arm to make the head lighter or can you do the adjustment near the tiles up tighter apart from this attach unsightly bracket from the head back to the wall at worst mate start pulling tiles off ouch ! wish i could more help glenn..
Nov 20, 2008 | Grohe 27.217.EN0 Rainshower 6" Ceiling...
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Home Logo
23 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
