Question about Health & Beauty
RE: Digital scale model SC 410 replacement for contact pad?
Posted by Harold Graber on
Tom Chichester
    Top Expert:
  • Health & Beauty Master
  • 60,304 Answers
Contact the manufacturer/distributor to inquire.
Posted on Nov 23, 2020
Replaced batteries and scale does not register weight, but just races through numbers and then "Err."
I have same problem with my scale. New batteries work for a few days. I'm throwing this thing out.
Oct 09, 2015 | Homedics SC-405 Glass Digital Scale Silver
SC-501 scale weight measures in Kilograms instead of centameters
Since centimeter is a measure of length, it would be difficult for any scale to measure weights in centimeters. It would be like asking a ruler to measure a length in kilograms.
Jul 25, 2013 | American Weigh Amw Sc-501 Digital Jewelry...
I changed the batter in my homedics scale model #sc-535 1606 and noe it does not work
Open it again and make sure the battery is in the correct angle..... I have made this mistake from time to time
Sep 12, 2010 | Homedics SC-405 Digital Bath Scale
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
Jan 28, 2010 | Health & Beauty
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Battery replacement
Check to make sure you inserted the batteries correctly the plus signs should be up. If that doesn't work I reccomend contacting homedics customer support as something is worng with the scale that you cannot fix there is a lifetime limited warranty on the product so its better to let them try to fix the problem.
here is support contact information
http://www.homedics.com/products/support
here is the information on the warranty
http://media.homedics.com/warranty/warranty_life.pdf
Apr 01, 2009 | Homedics Elegant Glass LCD Digital Scale...
Scale wont work
Sounds like a warranty issue. I would try to return to place of purchase if not here is web address on manufactures site with instructions on warranty.
http://www.homedics.com/products/warranty-returns
Nov 25, 2008 | Homedics SC-405 Digital Bath Scale
Olympus Stylus 410
try to clean the pad using water damped cotton if you are techie, professional fix is needed if you're not.
Sep 07, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Health & Beauty Logo
32 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
