Question about Home
Hi, I have a hydroclean 660 in my cistern. But the pipe that fills the water into the cistern is jumping around, and flooding my bathroom every time I flush. It's because the water coming out is making the pipe move up, causing the leak. Is there a way to secure the pipe to the bottom of the cistern without damaging it?
Posted by tilottama pillai on
  • 18,438 Answers
The blue pipe with the elbow? Zip tie it to the overflow pipe, put a brick on it etc.
Posted on Jul 24, 2020
5 Related Answers
Anonymous
SOURCE: westinghouse 906 leaks from front door
I’ve got the same make and model which had the same problem …if your sure its leaking from the door it will be coming through where the door jam or seal mounts and then leaking into the wall…..what you need to do is get yourself a tube of industrial silicon sealant and bead some silicon along between the back of plastic door seal mounts and the stainless steel wall lining...then allow silicon to set for 24 hours before running machine again
I believe over time the carcase and doors do warp causing these leaks
Hope this solves your problem
Posted on Feb 22, 2009
Anonymous
  • 152 Answers
SOURCE: when tap or cistern is filling loud noise from pipes
This could be one of two issues.
1. You may have high water pressure, causing the internals of the fill valve to vibrate and that vibration wave being transferred to your water pipes causing a reverberation noise called hammering.
An easy fix for this would be to reduce the flow to the fill assy. by turning down the units supply valve from wide open to about half way open. A few more permanent solutions may include, The installation of a Water hammer damper device - installation of a PRV pressure reducing valve - Although not intended for this issue is an air charged bladder style expansion tank installed, this device has been proven to reduce water hammering.
2. Water pipes that are not properly secured, loose and allowed to shake when there is a sudden surge of flow pressure. Much like a garden hose flexes when the nozzle is quickly turned on. This issue is most common with CPVC (plastic) water lines due to their flexibility and will require many more secure points.
A fix for this is a bit more labor intensive, due to having to access the un-exposed water lines in walls and ceilings so as to inspect and/or re-secure them to their surrounding structures.
A tip for securing the pipes where they penetrate through wall studs is to inject an expanding foam product in to the studs penetration, hence when the foam expands and cures it will form a very snug fit.
Note: if ether of these are the case, the problem should not be allowed to continue, because water pipe leaks could occur at the solder or welded connections and/or at locations where the pipes are rubbing against an abrasive surfaces causing a rupture.
Good luck
Aduz
Posted on Mar 27, 2009
Anonymous
  • 5 Answers
SOURCE: I have a leak at the bottom of the cistern where
It may be that the washers are worn out, or you might have the nut too tight.
Posted on May 02, 2009
Anonymous
  • 1305 Answers
SOURCE: Loud hammering noise with vibration on piper when the cistern fil
You're experiencing "water hammering" it's solvable too.
You can buy anti-hammer add-ons which you can put under a nearby sink, or even on an outside hose bib. This will give the water pipes an air "shock absorber"... since air compresses it cushions the abrupt changes in the pressure where as if it's just water, it'll slam and hammer and vibrate...
Try an anti hammer device added to you supply... you should be able to add it with out too much tearout.
K
Posted on Jun 20, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
Posted on May 04, 2010
Why does the water supply pipe hammer once when the cistern is full
When the valve filling the cistern shuts off it does so qu icky causing a rapid increase in pressure in the supply pipe this causes a bang in the piping called water hammer. There is a device called a hammer arrestor which,when installed will absorb the shock of the closing valve and eliminate the hammer. It is basically a spring loaded rubber diaphragm. A section of piping in which air was trapped used to be used as an arrestor but over time the air would dissolve into the water and would quit working the new spring loaded diaphragm type are best way to go.
Hope this helps.
Bob
Oct 19, 2014 | Plumbing
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Can a Grundfos pump fail, letting water out of a cistern?
Glad you got it fixed. Hope you didn't lose all your water in the process, we've been that way at times with our little system (can only afford 450 gal of storage with 650 gal transporter, no well).
Watch those strains on the pipes and make sure any further changes have good one way flow valves for this type system, expense doesn't look so bad when the alternative is being waterless!
Sep 01, 2012 | Grundfos Pumps Grundfos sqflex submersible...
We used to have a separate toilet next to the bathroom. When we have the loft extension built the WC was relocated to the bathroom to make way for the new staircase. Since then we have very low pressure...
The water all comes from the same place usually. What you need to check is your supply line to that area the supply should be larger than the feed lines, depending on the code in your area. The supply carries more volume to your usage areas that's why it should be larger, then you tap off of the supply with smaller pipe to connect feed lines to receptacles. To long of small feed line runs lead into problems maybe such as you have. Was the job inspected by your town or local agency? They might have caught such a discrepancy.
Jun 08, 2010 | Plumbing
The toilet cistern is filling up but the toilet pan is not getting enough water presure to empty
check that the water in the cistern is up to the mark etched on the inside
Do you have a close couple or a washdown [with pipe from cistern to pan]
Mar 04, 2010 | Home
The toilet was installed under the stairs a year ago and has hardly been used - the bowl keeps filling after flushing and overflows, I cant shut it off. It flooded the down stairs twice now - all over...
Take the lid off the cistern tank and have a look. There is a ( usually ) round float ball in there. This is what is causing it. When the cistern fills up the ball is supposed to float up and the arm it attaches to shuts off the water, usually at the opposite end to the float.
Turn the tap on the pipe to the cistern so it is nearly off and move the arm up and down by hand. See what it is getting stuck on or what is happening.
If it is not a simple sticking problem, you may need to undo the top of the cistern valve itself ( opposite end to the ball. )
Turn the water off completely to the cistern to do this or you will get squirted. :)
They are fiddly little valves and all a bit different but if you take your time and make sure you have a good light you will be able to work out what has been happening.
Hope this is some help.
Oct 17, 2009 | Saniflo SaniBest-Round SaniBest Macerator...
K
Jun 18, 2009 | Caroma 270W-RF Reflection Round Front...
Toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Apr 21, 2009 | Kallista Michael S Smith Country Elongated...
SA 660 SMEG dishwasher constantly filling....
this can be water draining from your sink into the dishwasher via the drain pipe, assuming the drain pipe goes to a spigot on the sink trap.
take the drain hose up as high as possible in a swan neck to prevent this.
Jul 17, 2008 | Dishwashers
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
