Craigslist Kitchenaid side-by-side kscs25inss00 has been plugged in for about 28 hours. Freezer is icy, but the refrigerator is not getting cold.Thermostat beeps twice followed by clicking. Cycle repeats every 2 seconds. The clicking is from the damper door, already fully closed, trying to close. The motor works; I've manually opened the door and watched the motor close it. What do I do?
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective. It may only be stuck.
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
SOURCE: Refrigerator door won't stay closed
Pull on the gaskets some times they are broken and will take up moore room that when correctly aligned. especially on the side of the door where the hinges are. Inspect thehinges also see of brackets are loose. If the gasket is bunched up on the hinge side try duct taping them down and retry the door. If this corrects problem replace door gaskets. If a plastic grommet is missing in the door it will nolt align correctly and you will be able to pick up on the outer corner of the door and it will wobel and be loose on the hinge. ReplACE THE GROMETS and retest and align as nessary.
SOURCE: Refrigerator Door won't stay closed
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Part 12 on this diagram is your cam.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB27FHSS02&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=O2030395&backToLink=Return%20to%20Sub%20Components%20list
Testimonial: "The most helpful and complete response I received. The link to the schematic was a great deal of help. You are a true Pro and I appreciate your help."
