SOURCE: Blank screen when tv has been on for 10-20 minutes
Hi jilanfa00,
I am happy to help, we need to check the backlight inverter.
If you see an image you have a bad inverter, you should be able to replace it yourself. I can walk you through in chat. Let me know your findings. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: no screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
SOURCE: No screws to mount AKAI LCT3701AD LCD TV.
Hi i bought mine at home depot for a few dollars they were very helpfull there and they worked great...
SOURCE: I get sound on my tv but no picture. not even volume bar or menu
check to see if there is an image on the screen by putting a light close to it if ther is an image replace the backlight inverter
