Question about Amana Refrigerators
Measurements for Amana side by side refrigerator model SZD23VL
Posted by Paul Boivin on
Tom Chichester
    Top Expert:
  • Amana Master
  • 57,253 Answers
Request from Amana or an appliance dealer.
Posted on Jul 22, 2020
5 Related Answers
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Posted on Jul 08, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Posted on Feb 19, 2009
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Posted on Aug 05, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: I am looking for a wiring diagram for the Amana
Look behind the toe plate for the tech sheet. Hopefully it was not removed with the packing materials. If it is missing try here
http://www.apwagner.com/index.php?main_page=product_info&products_id=566096 the part number is RT1300013
Posted on Oct 12, 2009
Sheikhtijani
Shehu Pro
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
What is the fridge/freezer capacity for the Amana BZ20RW?
I can't locate your particular model online, but you can figure the cubic feet yourself
Empty your refrigerator /or freezer to facilitate easier measuring. Measure the height, width and depth of the refrigerator's interior.
Measure in inches, and write them down.
Multiply the measurements this way: H (height) x W (width) x D (depth).
This is the interior capacity of your refrigerator in inches. To convert the number to feet, divide the number by 1,728. This converts cubic inches to cubic feet.
I hope this helps you. Thank you for using FixYa. Your rating of this answer is appreciated.
Dec 26, 2010 | Amana Refrigerators
Amana side by side. Freezer is working. Refrigerator isn't'!
  1. take all from freezer side out
  2. open back wall
  3. check if the fan is damage
  4. check the heater element
  5. check thermostat
  6. one of them is bad
  7. good luck
Jan 01, 2010 | Refrigerators
Find a replacement for Kitchenaid KEMS376S ~ tricky dimensions
your local dealer shouold have available to them all the manufacture specs and which unit would fit your needs.
Mar 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Parts list for a Amana model # ARS266ZBS side-by-side
Try this link:
[url=http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167655]Amana ARS266ZBS Parts Listing[/url]
Feb 06, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Sep 16, 2008 | Amana Refrigerators
Amana side by side does not freeze nor does it get cold
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Jun 10, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
24 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
