Question about Rival Kitchen Appliances - Others
Rival fold and store griddle. Looking for a replacement for a knob for the heating element on one side and a nut that would hold stew in place for the one side
Posted by Susan Visser on
Andrew Taylor
    Top Expert:
  • Rival Master
  • 34,028 Answers
2 Related Answers
Anonymous
SOURCE: Looking for replacement cord for electric
Finall found a website that sold replacement parts.
Posted on Oct 28, 2009
kebah
Angel Joseph Jr.
  • 684 Answers
SOURCE: Looking for replacement plates for
Hi there.
You can inquire and purchase Rival parts at http://www.rivalproducts.com
Regards.
Posted on Aug 28, 2011
Tip
How to Replace the Dishwasher Heating Element
If you have determined that the heating element has gone bad in your dishwasher then you may be wondering if you can easily replace it. Actually for many dishwashers the replacement is not that hard. The most important part is that you turn off all power before attempting to do any work!
The heating element is located in the bottom of the dishwasher tub. It will be submersed in the water when the dishwasher is running. To find it, look for a thin circular tube in the bottom of the dishwasher tub. Some dishwasher will have a cover over it. To get to the heating element the racks will need to be removed from the dishwasher and the cover, if there is one will have to be removed.
To replace the element you will have to remove the front kick plate of the dishwasher. A few screws will hold it in place and they are easily removed. Once you are underneath the tub you can locate the terminal ends of the heating element. Make the wires do you know which one goes where to put them back properly. Then pull the wires from the ends of the heating element. Make sure that you are pulling on the terminal connector and not just the wire to remove them.
Once you have the wires removed from the ends of the element, then look for the lock nuts up against the bottom of the tub that holds the element in place.
With a small adjustable wrench or a pliers you can loosen the locknuts. When the nuts are off of the ends of the dishwasher heating element you can then reach into the tub of the dishwasher and gently work the element loose and pull it up and out.
Place the new element into the holes and then securely fasten the new heating element in place with the lock nuts. Use a wrench or pliers to snuggly tighten the nuts. Replace the wires and the kick plate. Replace the element cover if there is one, the racks, and you are ready to roll. Turn the power back on and try it out!
on Apr 19, 2010 | Dishwashers
Looking for replacement plates for the Rival GRF405 folding griddle
Hi there.
Regards.
Aug 15, 2011 | Rival GRF405 Indoor Grill
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
Rival crockpot knob
Try the hardware store. Look at the dimmer knobs.
Jan 17, 2009 | Rival 3355 5-Quart
Looking for replacement knob for my red Rival slow cooker
My knob melted off my crock pot... I was left with a screw and a nut.
I replaced my knob with a knob from another glass cover from a sause pan... works great. (and it's a nicer handle).
you can get a cheep pan with a glass cover from a dollar store or thrift shop.
hope this helps
Nov 21, 2008 | Rival 38601 Smart Pot 6-Quart
Why does my crock pot cook at too high a heat?
With something that small, there is not a lot of resources for parts and repair. The item is considered a throw away. You could contact customer service at RIVAL and see what they say about the issue. Could be mis-wired or something like that. The only easily replaced part for that is the stoneware.
Jun 16, 2017 | Rival Crock Pots & Slow Cookers
Handle on crockpot lid broke off.can I replace it at store where purchased?
I have had the same problem. Spoke to rival customer service and they no longer sell replacement lids for model number SCE502. I've read to take the screw from the knob to a hardware store and then find a knob which will fit it.
Someone else suggested that if the knob is mostly intact, ask hardware store for araldite glue
Dec 08, 2007 | Rival 3755 5.5-Quart
Kitchen Appliances - Others Logo
19 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Colin Stickland
Colin Stickland
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
