Question about Tools & Hardware - Others
Where can I get a push rod for an ET-50 staple gun? I have looked all over the internet.
Posted by Bob Swain on
Tom Chichester
    Top Expert:
  • Tools & Hard... Master
  • 60,215 Answers
Try contacting the manufacturer/distributor to inquire.
Posted on Nov 23, 2020
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 37,144 Answers
You can try contacting the manufacturer/distributor to inquire.
5 Related Answers
Anonymous
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
Anonymous
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
joboo1
Jim London
  • 257 Answers
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 27, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Testimonial: "Thanks for your help! Much appreciated!"
Anonymous
  • 3 Answers
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Posted on Aug 11, 2010
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
I have recently been given a Powershot 8000 stapler and having trouble loading staples ,how does it load?
With the staple exit facing toward you (don't squeeze the handle), find the small black square at the bottom (opposite end) from staple exit. Grasp both sides. Pull away from gun (not down). Chamber will open.
Mar 01, 2011 | Powershot Tool Company Cobra 8000 Forward...
I don't understand how to load a T-50 staple gun. There are never any pictures of the thing that you push. I think it may have broken off of my gun. If that is true, then it is no good? ...or is there...
we have one, you push in at the back and pull down take out the rod put the staples in and put rod back in and push up it locks itself, hope it helps
Jan 30, 2011 | Heavy Duty Arrow T50 Staple Gun
How do I open a model T-50 staple gun?
On the rear of the stapler (if you look at the picture on this web page, the lower right) there is a metal piece that you push in, then down slightly, to unlock. When you release it, a spring loaded bar and follower will come out. You will see where the staples slide in. Put the follower back in the grooves and reinstall.
Aug 10, 2010 | Heavy Duty Arrow T50 Staple Gun
Can u tell me how to load the staples into my arrow t25 staple gun not used it for a long time
Hello. Here is a link to a free manual for your stapler. http://www.arrowfastener.com/upload/manuals/79055000259_manual.pdf
Look on page 3 for the three steps to load it.
1. Press latch in lower rear of gun to remove pusher rod from machine.
2. Insert strip of staples.
3. Replace pusher rod.
Happy stapling! J.
Jun 22, 2010 | Arrow T25 Staple Gun
Don't know how to load staples in my powershot pro
Usually a black tab toward the back of the staple gun.
Push in, pull up and pull out.
Push rod, spring and assembly should slide out easily.
You can then reload as needed.
Push in, pull up and when the push rod bottoms out push down.
This usually locks the tab back in place. Do this a few times and you will get the feeling pretty quick.
Oct 18, 2009 | Powershot Tool Company Cobra 8000 Forward...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Jun 08, 2009 | Arrow T25 Staple Gun
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Tools & Hardware - Others Logo
35 people viewed this question
Top Tools & Hardware - Others Experts
Bill Boyd
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
