Question about Optics
We just got a 78-9676 telescope with no manual we tried to use it but things appear upside down we must not have something set up right help
Posted by Debra Thorn on
Tony Parsons
  • Optics Master
  • 6,275 Answers
You have not stated the make of this telescope, but from your description, it appears you have an astronomical telescope (for star-gazing). These scopes generally omit the correction lens in the optical path that inverts the image for terrestrial use. This is because light-gathering power is more important than orientation - after all, there is no 'up or down' in space.
It may be possible to obtain an additional correction lens - check with the manufacturer or seller. If this was not pointed out when you made the purchase, you may be entitled to a refund. Otherwise, just enjoy the Heavens.
Posted on Jul 20, 2020
Images appear upside down when I look through the eyepiece
Yes, that is the way with astronomical telescopes.
Perfectly normal. We don't care if the image is upside-down or backwards [flipped left to right]
Nov 11, 2013 | Galileo 800x 80mm Reflector Telescope With...
Telescope image at an angle
You do not specify type/model of telescope but:
If it has a diagonal, loosen the set screw holding the diagonal and rotate until image is upside down.
Dec 26, 2012 | Optics
Hi, Inherited a North Star Bushnell telescope. No instruction manual. I downloaded that. The little corded thing works but the motor doesn't seem to be working to turn the telescope in the right...
I don't know about the motor on this scope.
Astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear. It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one.
You remove the whole large cap to use the telescope.
I don't know about cases for this scope. I just leave my scope set up in the corner of the dining room.
Jan 22, 2011 | Bushnell Optics
How do I get the image to turn the right side up? When we first set it up the image was right side up for a few minutes and now it is upside down and we can't figure out how to get it to flip. The image is...
Dopn't worry about upside down. All astronomical telescopes show images upside down. There is no up or down in space.
You may have what is called an "erecting" prism diagonal that turns the image right side up. Just Google "erecting prism diagonal".
This may also help you.
http://www.cloudynights.com/item.php?item_id=810
Dec 27, 2009 | Edu-Science (10166) Telescope
I have a Tasco #45-060525 Telescope and have lots problems setting the scope up. Can't see a thing in it...Things appear up side down or too blurry or just too small to see...Interested in looking at the...
Astronomical telescopes ALWAYS show images upside down. There is no up or down in space!
Put the eyepiece with the largest number written on it into the telescope. Go outside in the day time and practice focusing on a distant object.
You do realize that you bought a 60mm telescope. Not much bigger than your normal pair of 10x50mm binoculars.
http://www.texasastro.org/telescope.php
Dec 26, 2009 | Tasco Optics
When i look in the finderscope the objects r upside down but when i look in the big one theres nothing,even when i try and zoom in and out thers nothing moving
Some finders show things upside down. There is no up or down in outer space.
During the daytime focus on an object like the top of a telephone pole a good distance away.
Without moving the telescope adjust the finder scope so that the "crosshairs" in the finder are centered on the same object as the main tube. Most astronomical telescopes show upside down and reversed images.
Nov 04, 2009 | Meade (r) TeleStar Manual 60mm Refractor...
Why when I look in the telescope does it view things upside down
Yes, that is normal wit an astronomical telescope. To make it right side up, use the mirror diagonal (look downward) and it will appear correct.
Aug 14, 2009 | Tasco Novice 30060402 (402 x 60mm)...
Image is upside down
A telescope sees that way. you have to have a corrective lens to right the view. Its a physics thing about how light goes thru a lens and at the lens flips over upside down, you need another neutral lens to flip it right side up again. If you got the entire kit try another lens till you find the corrective lens.
Jul 05, 2009 | Meade ETX-90EC (325 x 90mm) Telescope
Upside down images on my telescope. Bought used -no manuel. What to do?
In a refractor images are upside down as with most telescopes. You need an image erector to create a normal correct R and L and Up and Down image. It is a lens which goes in front of the eyepiece to give a correct image.
Jun 01, 2009 | Fieldvision 114mm Reflector (114 x 114mm)...
Optics Logo
26 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
