How to take apart Altec im310 ? - Audio Players & Recorders
Posted by Richard Means on
Andrew Taylor
    Top Expert:
  • Audio Player... Master
  • 34,047 Answers
Nothing exists on repairing one. Docking systems are a disposable item. Take it to an electronics engineer for diagnosis and repair.
www.manualslib.com > ... > Docking Speakers > inMotion IM310
return to the dealer, or call the Altec Lansing service line for assistance. IMPORTANT SAFETY INSTRUCTIONS 16. For products which incorporate batteries, ...
Altec iM310 inMotion Compact Audio System - YouTube
www.youtube.com > watch ? 2:52
Jun 14, 2010 - Uploaded by TigerDirect
Affordable, amazing sound for music lovers who listen with their eyes as well as their ears! This new addition to ...
Altec Lansing inMotion IM310 ' Manualzz
manualzz.com > doc > altec-lansing-inmotion-im310
User's guide Caution: To prevent the risk of electric shock, do not remove cover (or back). No user-serviceable parts inside. Refer servicing to qualified service ...
Posted on Jul 18, 2020
2 Related Answers
Anonymous
SOURCE: Wrong Power Supply
If it doesn't work with batteries or the supplied power supply than your speakers are fried. Sorry for the bad news.
Posted on Mar 03, 2009
Anonymous
SOURCE: i want to listen to music from my inspiron 9 threw im310
You will want to use a 1/8" to 1/8" Stereo patch cable similar to this one http://www.radioshack.com/product/index.jsp?productId=3612891 Just plug it into the headphones jack on your laptop then plug the other end into the jack on the back of your im310.
Posted on Jul 28, 2009
How to take apart altec lansing speakers to clean volume control
You do not take speakers apart to clean a volume control Do you know what you are talking about? I do not think so.
Mar 31, 2017 | Altec Lansing Audio Players & Recorders
I have been given a Altec Lansing iM310 speaker and in the box there are a few different sized dock adapters. I put the one that fit my ipod best in, and my ipod sits nicely and works. Since then I have...
Hi there , not long ago I was having issues with my VS 2420
I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following
Contact: [email protected] , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Mar 20, 2011 | Altec Lansing inMotion iM310 Portable...
When I plug in my Ipod to the inMotion im310 portable speaker the Ipod screen says it is not supported, and it worked this morning.
Check the pins on the speaker and on the plugin on the iPod, that's the problem usually. Also, check if the iPod is truly compatible, even if it worked before it may not be. I have seen car chargers for say a 2G iPhone work for a bit then say incompatible, it happens. Here are the compatible iPods for the iM310:
Plays and charges
iPod mini;
iPod nano 1G, 2G, 3G, 4G;
iPod classic 3G, 4G, 5G, 5.5G, 6G;
iPod touch 1G, 2G
EJ
Apr 10, 2010 | Altec Lansing inMotion iM310 Portable...
Ipod wont play only charges. error occurs.
Reformat the i-pod and reload the songs !! swampratt200 !!!!!! AAAEEE!!!!!!!
Jul 21, 2009 | Altec Lansing inMotion iM310 Portable...
My im310 smokes and smells, I get no sound. Repair or replace?
Replace, the cost of repairing something made in china is usually greater than buying a new one. I would just get a new one with fresh warranty.
Jun 22, 2009 | Altec Lansing inMotion iM310 Portable...
I want to listen to music from my inspiron 9 threw im310
Jun 11, 2009 | Altec Lansing inMotion iM310 Portable...
Wrong Power Supply
Mar 03, 2009 | Altec Lansing inMotion iM310 Portable...
Can't open/disassemble Altec Lansing im310
There is only four visible screws on the outside of the unit, which are the ones that everyone's found already.  Two are in the battery compartment, two in the storage compartment.  However I managed to find the location of the other TEN!  You need to take off the screens on top of the speaker.  The safe way I managed to do it was by using a very small flathead screwdriver and I would start at the bottom and work my way to the top on the outside edge of the speaker grill, just putting it between the grill and the plastic and turning the screwdriver up a little and inwards.
Once that's off you'll see four screws around the outside of each speaker and an additional screw sunk in above each speaker.  Once the screws are off, slowly just start to wiggle the two sides apart.  They're together tight, so just be patient and work it open slowly.
I should also mention that the ends of these speakers (that the seam doesn't seem to continue on) is actually a thin piece of plastic on each side and is stuck on with really sticky double-sided tape of some sort or rubber cement, something like that.  If you're careful, you can pull these off (slowly, once again).  It'll make pulling the two sides apart a LOT easier.
Hope this helps!
Jan 06, 2009 | Altec Lansing inMotion iM310 Portable...
27 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
