Question about HP Office Equipment & Supplies
Error code 21.2:13 for HP Designjet T920 - HP Office Equipment & Supplies
Posted by aphryknchyld on
Ngoro
    Top Expert:
  • HP Master
  • 2,640 Answers
How to load paper for sending only
you old or it, or both, me, im older than dirt.
sending only does that mean faxing/?
hp920
HP DesignJet T920 Printer series
this?
ever heard of HP, they have a HUGE web site, one of the biggest on earth really, (for a manufacture..)
its not old, not really? but is ...
here are the books, pick one and read, RTM
T920? i think not.
https://support.hp.com/us-en/product/hp-designjet-t920-printer-series/5365093/manuals
nah , its the relic 920, HP has like 10,000 models of printers.
its a crazy number, the old ones are all really just trash,
we chuck them , and not wasted hard cash fixing them
when new one is cheaper, say $50?
OK it this old Junker.
its like a YUGO car now, useless.
the word SENDING in your post , confuses me...
why use that word? , you meant print right? i cant print and need to load paper.... ok.
HP has ZERO support on Relics like this but of you learn to google
1st hit shows, the old manual
https://www.manualslib.com/manual/432804/Hp-920c-Deskjet-Color-Inkjet-Printer.html?page=5#manual
i dont like that web site but the link is ok
do not download any software to see books , unless at adobe. actual.
the book can be found if you look carefully but most sites
now are infected, and books are the TRAP,
IT'S A BRAVE NEW WORLD.
Jun 19, 2017 | HP Office Equipment & Supplies
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Sep 30, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 18, 2008 | HP LaserJet 4 plus Printer
75 people viewed this question
Ekse
efs_perpends
efs_perpends
