Question about Stanley Measuring Tools & Sensors
The blade is stuck inside my Stanley fat max utility knife. How can I get them out.
Posted by Suzi Sharam on
ray gallant
    Top Expert:
  • Stanley Master
  • 69,204 Answers
BUY A CAN OF PENETRATING OIL AND SPRAY IT DOWN GOOD AND SOAK IT OVER NIGHT
Posted on Jul 17, 2020
How do you change the blade in a Stanley fat max knife 789
Don't touch the blade by hand use a pair of pliers. There should be a screw in the center of the handle, just remove it and you will see how to remove the blade.https://youtu.be/pFnbiw88Z8c
Oct 18, 2015 | Stanley Measuring Tools & Sensors
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Jun 26, 2011 | Stanley Utility Knife
Can't reload utillity knife fat max10-778
Hi Mark,
I have several of them. Are you having trouble getting the handle to open up?
I have found that the blade needs to be all the way in to open it. Also, to get the blade holder to sit right.
If this is not the problem, please reply back. Thanks,
Handie Andie
Jun 21, 2011 | Stanley Hand Tools
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Oct 29, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Measuring Tools & Sensors Logo
23 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
