Question about Frigidaire Freezers
I have a Frigidaire upright freezer. it is blinking O-F-F. What does that mean and what can I do to restart freezer. It is not turning on.
Posted by Ra Ha on
ray gallant
    Top Expert:
  • Frigidaire Master
  • 70,866 Answers
You call a local repair service .
Posted on Nov 25, 2020
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
Posted on Apr 20, 2009
Anonymous
  • 56 Answers
SOURCE: Frigidire freezer motor will not start, thasw out ice inside, then start up. Is the motor going out, or the cause is too much ice build-up.
more info would help but sounds like you have a defrost problem and need a technician
Posted on May 30, 2009
Anonymous
SOURCE: I bought a used Kenmore upright freezer, it's been running all the time.
I'm Not a pro, but the comments refer to a refrigerator. I don't think they read your problem from start to finish. I went to RSI in Phoenix, and I would say it is low on refrigerant. I hope it's 134a.
Good Luck
Over the years the freon sloowly leaks out, it might need only an ounce or two but it will fix it in my opinion. I have the same problem with mine.
Posted on Jul 29, 2009
Anonymous
SOURCE: Freezer will not turn on
I have a whirlpool upright freezer model ev190nxsn01 it keeps popping the breaker. i disconnect the timmer the comp runs,ichanged the timmer,still pops breaker, i disconnected evap fan still pops breaber. please help if possible thanks for your help.
Posted on Aug 04, 2009
TheMazz
Kevin
  • 79 Answers
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer orange and red light on but green light off can you advise? Frigidaire freezer.
Draw fan has failed, temp unreachable over the past cycle of 24hrs, turn your unit off for 24hrs and defrost it, restart and should work fine for a few days, if so, replace fan and defrost element only. Call service tech for this unless you are clued in on this work, not that costly.
Aug 28, 2011 | Frigidaire Freezers
The Temperature alarm is going off. What does this mean
The unit is not at correct temp, ""unsafe to keep food"". Needs service.
Hope that helps. Russ.
If you remove all the items from the unit and defrost it for 2 days with door open, on restart, should work fine..
Jun 11, 2011 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
May 29, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Is it normal for the freezer to go off periodically? It just seems to stop running and later it will start running again. I've had this freezer for 5 years and don't ever remeber this happening before.
By stop running do you mean become quiet or do you mean quit cooling and unthaw all the food?
If you mean turn off and still be cold then that is normal.
If you mean turn off and warm up that is not normal
Apr 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
Freezers Logo
50 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
