SOURCE: BROTHER PE-8500 EMBROIDERY MACHINE TOUCH
Never mind..I figured it out. Once you get to the number screen, you have to hold down the Start/Stop button while selecting the numbers. I did it 3 times and it worked! Icons are perfect now...Thanks!!!
SOURCE: I have an brother 8200 embroidery machine and when
If you take the face plate off (left side cover) there is usually a small sensor "lever" that is activated when you raise or lower the presser foot. This could be bad or broken. Many models had plastic then they switched to a metal lever. I think this could be it.
SOURCE: The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Warning - undertake this fix at your own risk as it will probably invalidate the warranty.
The problem is a bad connection inside the embroidery unit - there is a small plug that joins four sets of wires that comes loose.
1) disconnect the embroidery unit
2) Turn the unit over and remove the posidrive (crosshead) recessed screws on the bottom. ONLY remove the recessed screws NOT the ones holding the catch to hold embroidery unit to machine. ALSO DO NOT remove the one screw that is different (it has different head that allows a flat screwdriver as well as a posidrive)
3) Carefull turn unit back over
4) With the enbroidery unit facing you there is a screw facing you in the white cover of the hoop holder. Remove this screw and carefully remove the plastic cover.
5) On the underside of the hoop holder nearest you there are two black screws that are undone with an allen key. Remove these (they allow the main cover to come off
6) Pop out the long plastc cover under the hoop holder (where the ting moves back and forward)
7) Pop out the section of cover behind this that is now loose.
8) Carefully tease off the main cover. IT will come with patience and by moving the embroidery arm back and fortht to give space. DONT FORCE IT.
9) You will see the rails running left to right that the hoop holder moves on. Under these you should see four wires, that are joined to four other wires by a connector.
10) Wobble the connector to get them to connect again
11) Connect the embroidery unit to the machine and switch on.
12) If the carriage goes to the start position you have restored the connection. Secure with insulation tape
13) If not switch off, wobble, switch on unitl it works
14) Disconnect and replace covers.
Good luck. This sorted out our machine that just moved the carriage the wrong way and flashed red 88
SOURCE: feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Hey Mandy.. if you actually look at this account again will you please comment. I’m having the same issues with my machine and can’t figure it out.
