SOURCE: pioneer pd m502 cd player.
Hi
You may not be able to. Some older gear used to have this as a feature for using a central timer switching the mainsvoltage to al devices. If you wanted to do a cool weekend project, the best you could do would be design and fit a one shot 555 timer across the on off switch, that keys it back off after say 1 second. OR You can find a specialist reset devices that will supply a "pulse" to operate the switch electronically.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
are still unsure, or have problems, then before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
SOURCE: require a users manual for
Direct Download Link for manual :)
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/282719879PD-F407%20PRE1297A.pdf
SOURCE: I need a user/operaing manual
yes The
most common thing to be mounted is a hard drive partition. Hard drives
are kept in /dev and have different names depending on what type of
drive they are. IDE/ATA drives are labelled as /dev/hda, /dev/hdb,
/dev/hdc and /dev/hdd (since a PC's IDE interfaces can only handle 4
devices at a time). Note that these can be devices such as IDE/ATA
CDROMS, Compact Flash to IDE converters, and some special floppy drives
(although they tend to appear mainly in laptops). For SCSI devices the
labels are /dev/sda, /dev/sdb, /dev/sdc, /dev/sdd, /dev/sde, /dev/sdf,
/dev/sdg, /dev/sdh and /dev/sdi (since a SCSI chain can contain up to
nine devices). Other types of drive, such as USB, SATA, etc. are mapped
to these SCSI devices by Linux. Therefore SATA and USB drives are
labelled as /dev/sdX where X is a letter, starting at "a". Since these are literally the devices you can issue a command such as: If /dev/hdc is a CD drive then it will eject. In
the case of hard drives, there is another abstraction. A hard drive
(and many devices such as USB "sticks" which act like hard drives) can
be partitioned to allow many filesystems to be stored on them. This
means that the filesystems themselves are accessible via the partition
labels, such as /dev/hda1 (the first partition on /dev/hda). This means
that we finally know about something we can mount, a partition, since
it contains a filesystem. Another
physical filesystem which can be mounted is the ISO9660 filesystem used
on CDROMs. Since there is only ever one CD in a CD drive there is no
point creating /dev/hdc1 (where /dev/hdc is a CDROM drive) since there
is only one filesystem on it. That means that you can mount CD drive
devices explicitly, so if /dev/hdc is a CDROM drive then it is possible
to mount /dev/hdc if there is a disc in it. Floppy
disks only contain one filesystem, and are labeled as /dev/fd0 for the
first drive, /dev/fd1 for the second drive, etc. So now we know three
things which can be mounted. Devices
like USB sticks are treated like hard drives (so /dev/sda1, for
example, may contain a filesystem) and so are iPods (although I think
the main data on an iPod is stored on the second partition) Mounting
is not restricted to physical devices. If you have a filesystem "image"
(which IS a filesystem, whether an exact copy of an existing
filesystem, or a filesystem created specifically for that file) then
you can mount that through the use of a fake device called the
"loopback device"
Firstly
I will tell you how to unmount any filesystem you mount after trying
these commands. Unmounting is done through the "umount" command, which
can be given a device or a mount point so: Would both unmount the filesystem on /dev/hda1 if it is mounted on /mnt. Remember
that a filesystem cannot be in use when it is unmounted, otherwise
umount will give an error. If you know it is safe to unmount a
filesystem you can use:
What Can Be Mounted
sudo eject /dev/hdc
How To Mount/Unmount Filesystems
Unmounting
sudo umount /mnt
sudo umount /dev/hda1
sudo umount -l /mountpoint
SOURCE: I need a user manual for pioneer pd-f906 101 disc
Click here to download the user manual to your device.
