Wirlpool duet sport want turn on - Washing Machines
Posted by Katie on
ray gallant
    Top Expert:
  • Washing Mach... Master
  • 68,634 Answers
WILL NOT IS BETTER THAN WANT
Posted on Jul 23, 2020
3 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: i have wirlpool duet sport
"F21" is a Long Drain error. Its usually an indication that something is clogged in the drain pump and/or drain lines. The following link explains how to correct:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Now, your diagnostics procedures may differ, but the procedures for accessing and cleaning the pump are the same. It doesn't take much to damage the small drain pumps in these washers. If anything has been caught in the pump impeller or motor for any significant period of time, the pump may be running, but it may NOT be pumping anything. If you perform all procedures outlined in the link provided and the error code reappears, you will need to replace the drain pump.
If you need a replacement drain pump the following websites are great sources to obtain one - searspartsdirect.com, repairclinic.com and pcappliancerepair.com. Just type in your COMPLETE model number to begin your search. All three offer competitive pricing, so take a look at all three. These are the cheapest web sources I have found for appliance parts.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 26, 2008
Anonymous
SOURCE: Wirlpool Duet Sport Washer shows no indication of power
That happened to mine I had to replace the "brain" of the washer....the part was about $170. I think it is called the control panel.
There is a test you can run...look in the manual.
Posted on Jul 02, 2009
john_cross
  • 6277 Answers
SOURCE: starts cycle with add a
Whirlpool F21 (and 16, 18, 20 and 22) states 'control unit failure'. Could be poor connections but requires a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
Starts cycle with add a garment light on. after few min f-21 code on with all lights flashs .cleaned drain pump filter. wirlpool duet sport model #wfw8300swd
John C
Jun 16, 2011 | Whirlpool WFW8300SW
I have a wirlpool duet shes abou 5 or 6 years old i cant wash she will get about half way throug a wash and statrs beppen and in the window it shows f2 what does F2 mean
F-2 would be slow drain meaning it takes to long to drain over 8 mins///Remove your frount kick panal at bottom of washer//behind that you should see your pump your unit should have a cleanout that you turn counterclockwise to take out//remove it and you will find all kinds of goodies that will slow the flow of water/if there is nothing in there then you will have to test the pump....need more help just ask....good luck
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The control locked light is on and I can't get the washer started , I just finished cleaning the compartment that you put the detergent in
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MY DUET SPORTS DOES NOT DRAIN.
your pump is probably plugged or the impeller on the pump motor is not turning properly and jamming.
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace whirlpool washer Drum, baffle
Just order a new one from an online parts store and put it in.  The new ones dont screw from behind.  They just snap in. By the way, the rest of the baffles will break as well. So you may as well by a couple.  But there not cheap-You can order them through Sears and pay 23.95 each.
Mar 09, 2009 | Whirlpool 8572546 Duet Sport Stacking Kit
Open Questions:
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
