Question about Vizio Televison & Video
Please help me fix my Vizio E601i-A3 that cycles on and off every 10 seconds.
Posted by Patrick D Griffin on
George Gibson
    Habit-Forming:
  • 21 Answers
Vizio TVs have an auto-off function intended as a power-saving feature. By default, the TV will turn itself off if it detects no signal for ten minutes. You can disable the Auto Power Off feature from the sleep timer menu.
Posted on Jul 23, 2020
Turn the TV on black and gray vertical lines going across the screen (like pen stripes) and can only be seen in the black or dark areas after 10-30 minutes they disappear and the screen is fine.
In most of the case, the problem is a defective data buffer IC located on the flex cable between the LCD panel & the panel buffer board, this problem can't be repaired, you have to replace the panel
Aug 29, 2017 | Vizio Televison & Video
Vizio Model E601i-A3 not staying on
Shorted main board would be the next issue. Not worth it to repair, replace it.
Jun 07, 2016 | Vizio Televison & Video
How to diagnose television fault?
diagnose television fault Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1491814-common-diy-diagnosis-repair-info-plasma-led-lcd-ccfl-lcd-tv-sets-monitors-display-devices-mostly-power-supply-repairs.html
How to Diagnose TV Problems
http://www.repairfaq.org/samnew/tvfaq.htm
Latest Repair Tips
Apr 16, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How to fix no picture on vizio e601i-a3
Try the flashlight test for image in a darkened room. If you see image checkout the inverter board.
Mar 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 07, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Televison & Video Logo
95 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
