Do I need a setup disc for my onn monitor...i can not get my onn monitor to work on my computer as my second screen.
Posted by elizabeth mills on
Vernon Taylor
  • Computers & ... Master
  • 6,657 Answers
Depends whether you need your second screen to be a duplicate of your main screen or a split between the two or a different screen altogether.
I can't tell you how to do it but I remember something about it in the Windows help menu.
Posted on Jul 15, 2020
Screen dead
connect a desktop monitor to VGA port from your laptop. if there will able to see the displays?.. you can go to control panel to reset the display settings and back that on to the normal screen settings.
Sep 05, 2014 | Dell Latitude D610 Laptop Computer -...
My toshiba nb240 starts with a blank screen with power and hdd and wifi lights onn, but nothing can bee seen on the screen. and when i off it it goes off with a sound.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 20, 2011 | Computers & Internet
My monitor goes blank after a few seconds of turning my computer on. I turn off the monitor & turn it back on again and it only stays on for a few seconds thanks
It basically goes to Power Save Mode. Check for the same error in System Setup screen, if the Monitor goes off in System Setup then you better need a replacement. Else you would need to reseat the Video Card(If any) and the Memory Modules. Please keep posting for any further issues / improvements.
Dec 30, 2009 | Dell Computers & Internet
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
Philips Brilliance 200w6cs Backlight off Green LED ONN
Check to see at one of the pin on the inverter board has 12vdc feeding it. No bad capacitors? Pictures?
Nov 29, 2009 | Philips Brilliance 200WP7ES - Flat panel...
Blu ray disc player freezing up
Not really a solution, but I have a new BD-P1600 and I can't have it work OK with my I-Inc 28 inch monitor in HDMI. It got the blue screen with Language choice the frst time I plugged it and choose the language, but after that it always stops displaying after a few seconds of blue screen. I plugged the unit to normal yellow video connector of a 20 inch TV and I configured the output HDMI to monitor but the player continues to stop displaying and hang when getting to no-disk. Sometimes, when pressing the SETUP on the remote, I can see SETUP on front display, sometimes not, but never got it on the monitor screen it-self like with the 20 inch TV.
Will I need to return to Futureshop change it for another new one?
Oct 04, 2009 | Samsung BD-P1600 Blu-ray Disc Player
Dell e176fpm can't enter setup
As you probably know, these settings are made in the monitor setup, not through the computer. Monitor settings vary a lot, so it would be hard to even give a generic answer, but for sure you have several buttons either on the bottom or side of your monitor. Keep trying to push any of these (Left to Right or Top to Bottom) (except the on/off button) until you get a setup popup screen. On some models it jumps right up, on others you may have to hold in for a second or so. Then the next menu is from one of the other buttons. Usually there will be two buttons for + and - for adjustment and also for one screen to the next.
Dec 23, 2017 | Dell E176FP 17" LCD Monitor
SCREEN READS NTLDR IS MISSING
Hi TAPOLA,
If you are getting this message, then rhe problem is not with your monitor at all. It is actually with your Windows XP operating system. Your monitor is working fine. Though to fix the problem you would need to get your Windows XP CD and boot off the disc, if you boot from the CD you will get a brief message "Press any key to boot from CD..." as soon as you see that you need to press any key within 5 seconds. If done successfully you'll see a different screen and its a blue screen with loading files on it. Afterwards it will be on the setup page so press "R" for recovery console and on the command prompt you need to type this command: CHKDSK /R and it will run scan and repair of Windows.It will take sometime, afterwards it will bring you on the prompt and you just need to type EXIT to reboot the system. Just let it reboot to Windows and see if it works.
Hope his helps!
Peace! :)
Oct 22, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Computer not working with Samsung LCD TV
Your PC isn't working, the "CMOS Checksum Error" is a BIOS error. It has nothing to do with the monitor.
You have to let the PC load the default settings and try to boot up, if the defaults doesn't work, you have to reconfigure the options in the SETUP program. To enter Setup press "Del" or "F2" in the POST screen.
May 05, 2008 | Televison & Video
Computers & Internet Logo
18 people viewed this question
Ekse
Marvin
Marvin
