Question about Mitsubishi Televison & Video
My mitsubishi dlp tv WD 60737 picture is dim beyond brightness adjustment yet there are no error lights on the front. I need a new lamp?
Posted by Wayne Scott on
Andrew Taylor
    Top Expert:
  • Mitsubishi Master
  • 33,311 Answers
Yes you do, or trade in that antique for a new one!
Posted on Jul 14, 2020
5 Related Answers
premtech
William Rayburn
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
Anonymous
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
Anonymous
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
milkburp
Adam Halfhill
  • 416 Answers
SOURCE: Screen is dim. Have brightness turned up to max
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Posted on Mar 15, 2010
tthekraut
Robert Dahmen
  • 374 Answers
SOURCE: My dlp tv seems to be dimming.. Is that the lamp
it does sound like your lamp is going out. this happens after 2.5-5 years depending on the tv and amount of use. You can find cheap replacments and sometimes can get them a discount if you buy 2.
comment if you need sites or info on replaments
Posted on Mar 17, 2010
Testimonial: "Thank you for answering my question. Have to find the right bulb for my tv now.."
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Mitsubishi wd 60737 screen going dark
Kindly adjust brightness/contrast/sharpness settings. If there is no improvement, this might require attention by a qualified service technician.
Jul 12, 2012 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi DLP - WD-60737 - 1 year old I have sound but no picture. The lamp is not lighting up. I have already replaced the lamp. After I replaced it, the set worked fine for a couple of hours, but is...
This tv has self diagnostic feature that will show last error through front light blinks, there is procedure to activate and read out error code to diagnose problem section of tv to solve its issue so to get tv back in business.
Let me know to proceed.
Thanks.
Mar 03, 2011 | Mitsubishi WD-60737 60 in. HDTV
Turned on tv, no picture, only sound
the problem is likely the projection lamp .. you can replace that yourself if you are handy .. you must unplug the set and make sure everything is cool ...avoid getting finger prints on the new lamp ...here are a few places where you can get a new lamp ... you can also see what it looks like on this site ...
http://www.bluestar-online.com/Mitsubishi_Model_WD_65731_Replacement_DLP_Lamp_p/wd-65731.htm?gclid=CLb9k4zf-6ACFdk55QodwT3dxw
the lamp is likely in a cubby in the back of the set (where you used to see the bright light) ...
the lamp is mounted in a cage ... you can get the lamp already mounted in a new cage from here ...
http://purelandsupply.com/WD65731-Mitsubishi-DLP-TV-Bulbs.html
......it costs more mounted but its easier to change and you will need a new cage if yours is damaged .. from the site above you can see what the cage looks like with the lamp already mounted ..
your lamp is a model 915p049010 ... that is available thru amazon at a good price here:.(includes cage)........
http://www.amazon.com/Mitsubishi-915P049010-Lamp-DLP-TV/dp/B001AJ8RAA/ref=dp_cp_ob_e_title_0
Apr 10, 2010 | Mitsubishi WD-65731 65" HDTV
Screen is dim. Have brightness turned up to max setting. Does the lamp get dim with age? Mitsubishi WD-Y577 dlp rear projection tv
Mar 15, 2010 | Mitsubishi WD-Y577 Television
Best settings for moderate to low light viewing?
Using your remote, click the "video" button (mid area, Right hand side) and adjust the brightness, contrast, etc., to your liking. Only you know what you like. If your picture can be "plenty bright enough"...then just make the necessary adjusts to whatever looks best to you. If your picture is "very dim" no matter what the video settings are, you need a complete cleaning of all lens, mirrors, and screen...and possibly a new lamp.
Apr 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
