Question about Ps Televison & Video
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 26, 2020
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
SOURCE: Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Posted on Dec 22, 2009
SOURCE: I have a Samsung HLR5067WAX/XAA 56 inch, rear
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Posted on Apr 26, 2010
Testimonial: "Thank you! "
Oct 06, 2012 | HP Pavilion dv6t Notebook
Mar 09, 2010 | Akai PDP4273M Television
Oct 21, 2009 | Samsung LN32B460 32 in. LCD HDTV
Apr 15, 2009 | Televison & Video
Jan 17, 2009 | Prima CV2011 TV
Jun 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Aug 23, 2007 | RCA F36668 36" TV
May 22, 2017 | Ps Televison & Video
I'm only getting 1 answer back I guess people on this site don't care about helping other people I will find my answer else where
