Question about Frigidaire Washing Machines
I have a Frigidaire affinity front load washing machine that is seeing pause when I hit the start button and I am plugged it from the wall for five minutes plugged it back in and tried to start it and it is doing the same thing what do you recommend
Posted by Missy snook on
Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and...
Unplug it for 10 minutes. Plug it back in and see if it starts and runs normally. If it doesn't then I'd suspect the pressure switch first then the control board.
May 10, 2017 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Every time I press start the washing machine goes into pause when pressing start button
its most likely a faulty button, press start once again and it should start the cycle. usually the start and pause buttons are the same ones.
Oct 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
How do I reset my Frigidaire Affinity Front Load Washing Machine? When I press a button the ERR code comes on and then it turns off.
My Fridgidaire Affinity front load washer has a ERR pause and I can't reset it. How do I clear this
Jan 17, 2010 | Washing Machines
Pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
