Question about The Computers & Internet
I'm a high risk senior in desperate need for tech advice. Want to purchase an inexpensive iPad for occasional online shopping and email. The computer room in my building is not safe with this virus. I'm not fussy, don't care if it's old or refurbished. Any guidence would be greatly appreciated. On social security with a very limited income. Please help. Deb
Posted by Deb scullin on
  • Larry Ng
    Larry Ng Jul 31, 2020
    just post for what is cheapest PC.
    answer used.
    best one is with w10 running now.
    or any PC 2011 or newer, no older, ever.
    that is all you need, desktop, laptop or pad.
    buy used DELL?
Anon
  • The Master
  • 1,354 Answers
Ebay might have inexpensive I Pads or Kijiji.
Posted on Jul 30, 2020
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: PRINTER WORKS FINE. HP.COM WINDOWS XP DRIVER WON'T COMPLETE DOWNLOAD BECAUSE OF POP-UP BLOCKER
Hi, Are you trying to send a print job to the printer ? Does the printer lights blink when you send a job ? Or are you just getting a pop up message on the pc?
Posted on Dec 04, 2007
Jim Keysor
  • 331 Answers
SOURCE: are norton security says that
NORTON, my luck with Norton has not been good, and as jeicrash mentioned, check your expiration. I have found norton is sometimes very hard to remove, Did you install from the internet or a disc. Calling Norton if you can get a person, will give you download sites that will fix this problem, they will also tell you if your Norton is up to date and paid for. Personal advise if you have to purchase I would not. There are good or better Anti-Virus protection out there at a less expensive price that does not slow you computer down as much as Norton and for that Mcaffee is about the same as to slowness. What happens when you try to download the updates???
Posted on Jul 28, 2008
Anonymous
  • 8 Answers
SOURCE: audio is off in security mode
You should try downloading the Owner manual to see what the means exactly, you can download the entire manual at Crutchfield.com
Posted on May 04, 2009
Bob B
  • 272 Answers
SOURCE: 2GB High Speed SD Card for Nuvi 255W
Yeah you can use any of the Ultra High speed SD cards usually around $25.00 on-line for a 2gig. High speed has a transfer rate of about 2MG/Sec The Ultra's are around 15MB/sec transfer rate so make sure that you get a high speed one and you'll be fine. The $6.00 ones are not what you need too slow for map displays.
Posted on May 10, 2009
bandana_gyrl
Sarah McDonald
  • 181 Answers
SOURCE: Error Oxc19ac3ff on my HP Photosmart Ct100 All-in-One series
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the "*" key. Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button.
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Aug 14, 2009
I have amini I pad and it says it is disabled how do I fix the problem
Stay connected to iPad Technical Support Phone Number 1-800-204-4427 for reliable Apple Help desk Support online. Get complete iPad Tech Support by expert technicians. Apple iPad Technical Support 1 800 204 4427 Number iPad Mini Air
May 31, 2017 | The Computers & Internet
With iPad must I join an internet even tho it is connected to my desktop usb?
Simply go to Settings-second down on the left menu, choose Wi-Fi and on the right menu, your home (or wherever you are) wi-fi connection should appear by name. Then simply touch the one you want to connect to. You should see the choice you made on the left menu next to the word Wi-Fi. I only connect my iPad to my computer to charge it occasionally via USB.
Sep 20, 2014 | Apple iPad (16 GB) WiFi Tablet PC
An emergency personal alarm for seniors with high risk heart problems?
There are several on the market from a audible alarm to the more sofisticated models that ring an emergency number when activated. They can be found at shops that cater for this equipment or at chemist shops that will give directions as to get them .
Oct 12, 2013 | Cars & Trucks
I live in the UK and I'm in desperate need of a new bandsaw blade .I have emailed the company in Florida on several occasions, but have had no reply..... Could you help? Kind Regards, annie
Email inquiries are mostly neglected due to heavy incoming messages and spammers. I have an online supplier for my metal cutting need for band saw blade ( sawblade.com ) . They don't have email on their website ,so the only way to make an inquiry is to call their toll free number. ( privilege for customers who live within US) . They made it that way because they don't want to receive emails from spammers. However, when you already purchase with them, they will communicate either phone or email - Whichever the customer is convenient with.
I understand that you're from UK but I think you should call the company.
Sep 22, 2013 | Diamond Tech International Diamond Laser...
[email protected] purchased Dell Desk top 580S C13 W7HB from Vijay Sales on 6th June 2010. Got it installed by a friend as I am a senior citizen needing advice on operations also. Generally OK but sound...
The speakers inside desktop computers (if it has one) are very small and do not produce a reasonable volume.
I suggest you purchase a powered stereo speakers and connect it to the audio out connector on the desktop computer. Powered speakers have better sound quality and adjustable volume controls as well as bass and treble controls.
Dec 15, 2010 | Computers & Internet
I need the diagram schematic the tv rca t19060gy 19 in I desperately need the schematic for a convergence amplifier problem w/a RCA 52" R52WH74...help!!
you can get the service manual for the ITC222 at the following link emailed to you and they provide free tech support to help you diagnose the problem when you purchase the manual. Heres the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | RCA R52WH73 Projection Television
Double copy on screen, difficult to read,
need help email me [email protected] live help thx nick
print issue dl latest drivers
May 19, 2008 | Compaq Computers & Internet
Internet connection cost
An alternative is to get CF wifi card and connect to internet through free hotspots that are available in places such as coffee shops and bookstores.
Sep 19, 2005 | Dell Axim X3 Pocket PC
Computers & Internet Logo
Top The Computers & Internet Experts
gardoglee
Level 1 Expert
Mike 'H'
Mike 'H'
Level 1 Expert
myxelpyxel
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
