Tv stuck in restriction profile, dont have password and no other functions will work on remote to access other menu.
I have an android skyworth 4kHD TV 8.0.0 version model globe
Posted by Stephanie on
Andrew Taylor
    Top Expert:
  • Televison & ... Master
  • 33,433 Answers
Pull the mains plug for 5 minutes.
contact the maker?
TV/Accessories / Other / Android TV - Android TV - Skyworth ...
www.skyworth.ph > tv-accessories > android-tv
Your browser does not currently recognize any of the video formats available. Click here to visit our frequently asked questions about HTML5 video. Missing: 4khd ‎8.0.0 ‎restriction
Dont see the option to set up restricted profile on Android TV ...
support.google.com > androidtv > thread
May 22, 2020 - I bought a Skyworth android TV model UB7500 in Saudi Arabia. ... profile in the settings (settings->Device preferences->security & restrictions).
Or RESET
https://www.skyworthphilippines.com/2019/09/how-to-hard-reset-skyworth-smart-tv.html
www.skyworthphilippines.com > 2019/09 > how-to-hard-reset-skywo...Sep 5, 2019 - Just SUBSCRIBE to our Service new YouTube account "Skyworth (Philippines) ... How to reset Skyworth LED TV to factory default settings? ... (Viewing phone screen to Android, Smart, Basic TV) ... Top Box PK T9 T95Q Android Tv box 4k Smart BOX Android 7.1 4K HD 3D 2.4G WiFi PK h96 max X96 Tv Box
Posted on Jul 13, 2020
5 Related Answers
Anonymous
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Posted on Nov 08, 2008
Anonymous
  • 133 Answers
SOURCE: Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Posted on Jan 08, 2009
Anonymous
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
thodges1
SOURCE: Need codes for Skyworth TV using RCA universal remote
http://www.marmitek.com/codelists/mt017.pdf
Posted on May 13, 2010
Anonymous
SOURCE: HAve a emerson SDTV model
how to use a universe remote for emerson sdtv
Posted on Dec 10, 2010
How can i access the menu without the remote control?
On older Televisions such as the one you have listed, you cannot access those menus without a remote control. Just to make sure I skimmed the user manual found here. The only suggestion I have is to get a universal remote with a menu button. Dont forget to check with your other remotes to see if they have universal functionality. Most receivers (surround sound units) have multi-function remotes. Also check your satellite or cable remotes to see if they have universal functions. You can tell, because they will have multiple buttons that say things like "TV, AUX, CABLE, ETC" If so, you can program one of these remotes (or grab one at most electronics stores to program) and have your menu available to you.
Also, check the link to make sure there isnt some functionality hidden away that I didnt see.
Cheers!
Feb 23, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
I purchased a used Emerson TV Model 3 CR202EM8 and dont have manual or remote...how do I reset password to access screen to enable me to change to video mode
go here if you cannot access the site: here are the instructions:
Your password will be erased and return to the default
(0000) when a power failure occurs. If you forget the
password, unplug the power cord for 10 seconds to restore
the password to 0000.
Sep 07, 2010 | Emerson CR202EM9 TV
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Sleep Function???
In most cases you can set the sleep timer by accessing the menu. Or if it is a learning remote find a button you dont use and teach it the sleep button from your OEM remote.
Apr 15, 2008 | RCA RCR460 Remote Control
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Channel stuck on TV
This may work;
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Feb 24, 2008 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Found it!
Dec 08, 2007 | Televison & Video
FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Sep 12, 2007 | RCA 27F650T 27" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
