Question about Craftsman Garden
My Craftsman 42 inch riding mower does not cut level the blades are good spindles are okay what else could it be
Posted by David Sexton on
Tom Chichester
    Top Expert:
  • Craftsman Master
  • 55,960 Answers
Damaged or worn shaft
Posted on Jul 13, 2020
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Its a 21hp 46'' cut craftsman yts 3000 riding mower
Richard:
Check your blades to see if they are balanced. They should sit level when you put them on an arbor, (something pointy that you can put in the hole in the blade that will not go all the way through the hole. If the blade is heavy on one side you can grind or file the heavy end of the blade (I sharpen the blades and the heavy side gets extra sharpening to remove the excess weight on that side). Also check the spindles that you bolt the blades to when you install the blades. make sure that there is no slop in the spindles... they must not wobble. If they wobble, you didn't keep them greased. You'll have to but new spindles... they're not hard to install.
Nov 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My mowers cuts uneven I replaced the blades but it still cuts uneven how can I level it?
Park mower on a level flat surface ( a concrete garage floor is ideal ) lift deck up until you can put a piece of a 2x4 flat underneath the deck and lower deck until it just contacts the 2x4. loosen adjustment nuts or turnbuckles and adjust until the deck just starts to clear the 2x4. this should level your deck. Now , lift the deck and remove the 2x4. put blade height lever on a known cut length and with a tape measure, measure the tips of the blades from the floor to the blade tip...they should all be the same within 1/8 of an inch...if not then you either have a bent blade, bent spindle shaft, or spindle bolts are loose or misaligned. Your deck could be warped too...depending on how hard a lick it took...good luck !!! ;-D
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Jun 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have to overlap about half my cutting deck to get clean cut.
A: Is the blade on right?
B: Is the belt on the pulley?
C: Is the blade tight on the spindle?
D: Does the spindle turn freely with the belt off?
I can't think of any other possibilities
Jul 03, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
May 25, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
