Question about Bose Audio Players & Recorders
Bose room mate will not connect - Bose Audio Players & Recorders
Posted by Donna Lavelle on
1 Related Answer
Andy Turner
  • 910 Answers
SOURCE: I have a Bose Lifestyle
Does it work OK when in the same room as the transmitter?
You may need to install an Antenna Extender to improve the signal.
Posted on Jul 24, 2011
Bose lifestyle one room doesn't connect and the remote says it won't connect to media center
Look in the instruction manual and make sure that you have set the codes correctly, the house code for the remote, as well as the room code for the second room. Also check the batteries in the remote control, especially when the room as far away from the main room, the batteries need to be full in order to reach the center. I assume we talk about a wired system? When this is a wireless connection to the second room, it may need a reset, unplug and re-plug the wireless adapter, there should be a pilot light in the back of the wireless adapter, which should be green. If that does not help, call Bose.
Jun 07, 2014 | Bose Lifestyle 48 System
Bose link AL8 will not connect with the Lifestyle homewide powered system
Your v35 system needs to be programmed to work with the second zone wireless unit. Read the instruction manual how to do it, or let a Bose dealer set it up for you.
Dec 27, 2013 | Bose link AL8 wireless home-wide audio...
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
Gettng my RC28T1 40 to connect with my LS28 system
i have a bose control, model RC48S2-40 and start the system but does not have control for volumen and change only from fm to cd dvd, is conected to other system bose from other rooms
Apr 10, 2009 | Bose RC-18S Remote Control
I have a lifestyle system with surround sound at central location and two remote rooms connected through two additional amplifiers. The central location works perfectly well. Recently, I started getting...
Probably the connection in the main room to the wirless transmitter. The problem is definitely between the media centre and the wireless sender as it is not effecting the main zone and is effecting both second zones. Multi pin connections can bend very easily if pushing the connection further in does not solve it you may need to replace the pins. why not call Bose tech?
Feb 19, 2009 | Bose SoundDock Digital Music System for...
Increase output of Lifestyle 18
apologies mate but what you hear at maximum volume (set volume to 99) is what the system can generate... The Lifestyle system are designed as stand-alone out-of-the box system and like other systems will only perform to their defined level. The only way is by using the AUX out (located behind the DVD/media center and connect either a pwoered loudspeaker or another amplifier (note that the output is fixed line so choose an amplifier with volume setting knob). with multiple loudspeaker of your choice. You may also go and buy expansions speakers from Bose itself
Again, glad to be of service...
Feb 06, 2009 | Bose Lifestyle 18 System
Bose link AL8 connection problems
I had a similar problem, though intermittent, using my 48 with the AL8 and room-mate speakers. I kept getting a "no signal received from media centre" message on the remote in the second room.
Assuming that the batteries are ok and you don't have a hardware problem, the problem might be that the 48 is not picking up the signal from your remote control in your second room. The signal from your remote control is a radio signal that goes directly to the 48 - it doesn't communicate via the AL8 receiver. I think the orange light will only turn green once a signal is being transmitted from the transmitter unit plugged into your 48 media centre, and this won't start transmitting until the media centre gets a signal from the remote telling it to switch on.
The aerial for all the remote controls is contained in the power cable that links the 48 lifestyle unit to your VS-2 unit. Make sure that this is uncoiled and oriented vertically, as far away from other cables as possible.
If this doesn't work, you can get an antenna extender that plugs into the RC socket on the back of the lifestyle system. Again, orient this vertically. You can get these from Bose.
Is there anything in the wall that might be blocking the radio signal? Lots of metalwork for example?
If orienting the power cable from the VS-2 doesn't do the trick, I suggest that you go to a local Bose shop. (An actual Bose shop, not just an electrical or hifi store stocking Bose products). I explained my problem and the tech guy gave me an extender gratis (its basically just an FM aerial wire by the look of it). I installed it this morning and, so far, its seems to be working ok. As my unit is fairly new, he also offered to have the kit back in the shop to check it all out and, if that didn't work gave me Bose technical support number. He even offered, if all else failed, to send a guy out to my home to get it working - and I didn't even buy it from there!
Hope this helps.
Jan 04, 2009 | Bose link AL8 wireless home-wide audio...
Bose media mate speakers suddenly don't work after ....
what type of computer? desktop or laptop? have you changed or added a sound-card?
Jun 24, 2008 | Bose MediaMate Computer Speakers
Bose cine mate speakers
No it won't be like surround sound, but you'll have the next best thing: a nice, powerful, natural Hi-Fi sound. I have a 46 inch 1080p Sony connected to a Sony Blu-Ray and Bose Cinemate Speakers. No complicated rear speakers wiring, no awkward center speaker to hide. The only drawback is that Bose doesn't have (yet) a code to operate the Blu-ray player with the Cinemate remote control.
Hope this helps to make your decision.
Feb 17, 2008 | Bose Cinemate Digital Home Theater System...
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
