Question about Citizen Watches
SOURCE: 24 hr utc display is not synchronised with the rest of the watch.
Here is the link to get full instructions how to set or reset your watch (paste it into your browser):
http://www.citizenwatch.com/CUK/English/technicalinfo.asp?caliber=C650&ModelNumber=JR3060-59F
Choose: Interactive Settings Instructions.
You need a pair of speakers or earphones connected to your PC as all instructions are visible and audible.
Do not forget to rate, please.
Posted on Jan 06, 2009
SOURCE: UTC hour hand off
I tried this on my C650 with success:
http://www.fixya.com/support/t468199-setting_model_number_jr3060_59f
Posted on Jun 17, 2009
SOURCE: Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Posted on Jun 25, 2009
SOURCE: Pod Watch, Trying to change the digital date
Somehow I have put mine right, I held the top lefthand button in and cycled using the bottom lefthand button, hope you can do the same.
Regards
Chris
P.S. If you get a copy of the instruction it would be nice to have a copy or the link.
Posted on Aug 01, 2009
SOURCE: My Citizen Skyhawk Eco-Drive JR3000-51F Wrist
I had the same issue, and was able to reset it doing the following:
1. I let it recharge for at least a day in bright sunlight
2. I turned the selector to "CHR"
3. I pulled the crown all the way out.
4. I held both buttons down for 5 seconds (don't know if this was what did it.
5. I pushed the crown back in.
It did some funky hand movements stuff and then started off working.
Posted on Aug 27, 2009
Mar 06, 2013 | Citizen Promaster Cyber Aqualand Nx Dive...
Sep 13, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Jul 21, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Jul 18, 2010 | Citizen Watches
Jun 05, 2010 | Citizen Eco Drive Perpetual Calendar...
Jan 31, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Nov 12, 2009 | Citizen Watches
Apr 05, 2009 | Citizen Watches
Dec 18, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
47 people viewed this question
