Question about Frigidaire Washing Machines
What does a low ohm reading on motor pins 1-2, 1-3, 2-3 Frigidaire LAFW7000LW0 washer mean? I got an E58 code. Seeing readings between 1-3ohms. Help?
Posted by jim dudley on
Error code E58
If you have a front-load washer that was manufactured by Frigidaire, the E58 error indicates high current on the motor. This could mean that the motor is bad, the bearings that the tub spins on are bad, or a problem with the speed control board. To test this, you'll need to access the motor and tub area of the washer. Unplug the power before opening the washer. Take the belt off the motor pulley and check if it spins freely. If it doesn't, then replace the drive motor. If it does spin freely, check if the large pulley on the tub spins freely. If that doesn't rotate, you'll need to replace the outer tub and spin basket in order to replace the failed bearings. If the pulley rotates easily, you'll need to check the motor windings. If the resistance is between 4-6 Ohms, the speed control board is probably faulty. If the resistance is not in the correct range, the motor is bad and needs to be replaced.
A Frigidaire washer technical data sheet is available here: http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf .
If your washer is under warranty, contact the manufacturer. If you add a comment with the model number of your washer, I may be able to provide a source for the parts.
I hope this helps.
Apr 27, 2016 | Washing Machines
How can I tell whether to replace motor, motor controller or main control board on my frigidaire affinity washer ( ATF7000FS1 ) after error code E56? Test 9 gives motor winding resistance of 7.2, 7.2 and...
Hello friend, thank you for your inquiry!
Based off the information from your manufacturer "E56" stands for high motor current. Looking up information for your technical data sheet it states that you need to perform test 9:
1. Remove the belt from the motor and spin the motor pulley.
Does the motor spin free? No, replace the motor. Yes, go to step (3).
2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3).
3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Based off that information you would need to replace your motor. If you feel unsure about repairs I would recommend reaching out to a professional for proper diagnosis and repair. I hope this helps. -Matt
Sep 15, 2014 | Frigidaire ATF7000 3.5 cu.ft. Affinity...
What is electrolux front load washer E58 error code
Good Morning Friend, I am happy to assist you!
I understand your Electrolux washer is getting an error code E58. It could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Hope this helps! - Z
Jun 04, 2014 | Frigidaire Affinity ATF7000E Front Load...
How do I fix E56 high motor current error on Frigidaire GLTF2940FS1
  1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free?
    No. Replace the motor.
Yes. Go to step (3)
No. Check the tub bearings.
Yes. Go to step (3)
3. Disconnect the plug from the motor and measure the resistance of the windings (pin1 to pin 2, pin 1 to pin 3, pin 2 to pin 3). All readings should be between 4 and 6 Ohms.
If the readings are correct, replace the speed control
board.
If the readings are incorrect, replace the motor.
Apr 30, 2014 | Frigidaire ATF6000ES Front Load Washer
Code 62 on frigidaire front loader washer
Disconnect the plug from the drive motor and measure the resistance of pins 4 and 5 in the motor. If reading is between 105 and 130 ohms, replace the Speed Control Board. If the meter reads outside 105 and 130 ohms, replace the motor.
Sep 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Washer wont spin code e57
High current issue - 1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 19, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer error 58
High motor current is recognized in the unit:
Aug 10, 2012 | Frigidaire Affinity ATF7000E Front Load...
F6 error code displayed
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed. If you have a volt/ohm meter I can give you a few checks that will help you diagnose the problem. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts. You will need to gain access to the MCU (Motor Control Unit), and ohm the motor windings and the tachometer . MCU connection should be as it is in your washer, there should be 5 black wires and 1 green wire. The black wires are as follows, pin 1 on top and pin 5 on the bottom . Set your meter to read resistance and check pin 1 to pin 2, pin 1 to pin 3, and pin 2 to pin 3, these should all read approximately 6 ohms. Next check pin 4 to pin 5, it should read approximately 115 to 125 ohms. If any of these readings are not very close to the values I have given you, check continuity on the wires from the MCU to the drive motor. If the wires check good, the drive motor is bad and will need to be replaced. If all readings are close to the values I gave and there is not an issue with the wires the MCU will need to be replaced.
May 02, 2011 | Whirlpool AWM8143 Front Load Washer
I have a F06 error code on my frigidaire washer model gltf2070cm. Please help. Is it an expensive fix? I will be waiting for your reply.Thank you, Karen Erickson
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
(tip courtesy JSRock)
Thanks for using FixYa&^$
Jan 28, 2011 | Frigidaire GLTF2070CS Front Load Washer
I started with E20, pulled the hoses off and the drain was clogged. I "put it back together" and now Im getting E59 code. What did I do wrong?
E59 No tacho signal for 3 seconds. This is a motor issue. follow the steps bellow to diagnose this issue.
motor pulley. Does the motor spin free? If the answer is no to the question, you will need to replace the motor. if the motor is free, move on to the next step.
measure the resistance between pins 4 & 5
in the motor. If the meter reads other than between 105 & 130 Ohms, replace the motor. If the reading is between 105 & 130 Ohms, move to the next step.
board.
May 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
