Question about Magnavox Televison & Video
I have a Magnavox 40ME325V/F7 that will not turn on. It has no standby light displaying when I plug the tv in and nothing when I attempt a power on.
Posted by Crazyguy _123 on
Tom Chichester
    Top Expert:
  • Magnavox Master
  • 56,042 Answers
1. Open fuse
2. Component failure
Posted on Jul 11, 2020
  • Crazyguy _123
    Crazyguy _123 Jul 11, 2020
    Where would the fuse be located I can't see any spot for one?
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
Philips 50PFL3708-F7 won't power on, LED indicator lights illuminates but the screen will not turn on.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 18, 2016 | Philips BRAND Original TV REMOTE for...
Put new 125V 4A fuse in and it keeps blowing it out.
Something on the powre supply board has shorted out.
Repair the board or buy a new one.
Dec 03, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
Magnavox 32MF301B/F7 32 in. LCD TV - my TV turns on by itself. What can I do about that?
Is it in a location that allows the sun to shine directly on it? Sometimes the light can trick the infrared sensor for the remote. Also, does the TV have any self timers enabled?
Feb 24, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
My magnavox 19me402v/f7 no power
If the TV has been shut down by its remote control previously, there is no other way than using its remote control to switch it back ON. If there is standby light, and the TV do not switch ON, use the remote control to power it ON. If there is no standby light at all, check and replace its main power regulator board. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic /Timeslide / Flipcard option.
Jul 23, 2013 | Televison & Video
Magnavox 19MD359B F7 19 in HDTV TV hung in Standby Mode. Light is RED but can't operate TV from set or remote. Will NOT come on!! Have cycled off (over 30 minutes) and tried pushing any combination...
You have a bad capacitor in the power supply. If you can remove the back cover, you may see a bulged capacitor or two. Replace these and your TV will come back to life. I'm sorry, I do not have capacitor values and locations at this moment. But, the fix should be fairly simple. If you have some elctronic experience, you can fix this. Thanks for asking and show all hands of support!
Aug 13, 2011 | Magnavox 19MD359B F7 19 in. HDTV
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Televison & Video Logo
Top Magnavox Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
