Question about Water Water Heaters
Water heater won't light - Water Water Heaters
Posted by Sid on
ray gallant
    Top Expert:
  • Water Master
  • 69,327 Answers
IT SOUNDS LIKE YOU MIGHT NEED PROFESSIONAL ASSISTANCE THAT YOU WILL HAVE TO PAY FOR
Posted on Jul 11, 2020
Pilot light won't stay lite is thermocouple bad?
Maybe, or maybe the FV system tripped.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
If you have error-code type gas control, then you have thermophile and not thermocouple
Troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 12, 2013 | Water Heaters
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light is lit but won't turn on water heater
What band and type water heater do you have? And about how old is the water heater? Add a comment with more information.
Following general information applies to tank-type residential water heater.
If pilot light is working, then thermocouple is good. Otherwise, if thermocouple was bad, or fallen out of place, then there would be no pilot flame.
Carefully read instructions for lighting water heater located on front of tank ... make sure you have the gas control valve set to ON.
At this point, troubleshoot varies widely depending if your water heater is older and air enters front of heater, or if water heater was made after 2007-9 and has sealed combustion chamber and FV system.'
Troubleshoot also varies widely depending if you have power vent and which type of gas control valve.
Copy following link for troubleshoot by type of gas control valve:
Also post detailed question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 16, 2012 | Whirlpool Water Heaters
Whirlpool water heater pilot won't light
Sorry to see you're having problems! Can you contact me directly so I can help?
www.whirlpoolwaterheaters.com/help
Thanks! ~ Chris
American Water Heater, authorized licensee for Whirlpool Water Heaters
Jun 17, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
Water Heaters Logo
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
