Question about Rinnai Heating & Cooling
What is the current equivalent of the Rinnai 404
Posted by Douglas Miller on
Tom Chichester
    Top Expert:
  • Rinnai Master
  • 56,060 Answers
Contact Rinnai to inquire.
Posted on Jul 11, 2020
404 not found
The website is currently up, you may need to clear your temporary internet files in order for it to display the current version instead of any cached version you may have.
Feb 18, 2013 | Computers & Internet
I have a Rinnai RCE 329H gas heater and no instruction manual of how to attach it to the gas pipe. Please could you advice. Thank you.
debbaruah - I have searched every Rinnai data base, on 3 continents, at my disposal and have not been able to locate a current Rinnia gas heater with the model number RCE329H. Are you certain that is the correct model number?
Please advise. Thanks.
Jun 09, 2011 | Rinnai Heating & Cooling
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
Air filter
404 K&N RU-1780
Nov 10, 2008 | 2007 CCM 404 DS Moto
Rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
senbukan
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
