Question about Furniture
I just got my rocker recliner today ... Why am I having a problem with the foot rest not staying down I have to push it to click in place with my hand.
Posted by Carol on
ray gallant
    Top Expert:
  • Furniture Master
  • 68,585 Answers
ASK THE PLACE YOU BOUGHT IT FROM
Posted on Jul 11, 2020
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
Lazyboy recliner foot rest will not stay up!
Check the spring that holds the foot rest closed or open. Flip the chair over and take a look.
Mar 30, 2014 | Furniture
Foot rest on recliner will not stay locked in position
your footrest spring has stretched out not providing proper tension to hold footrest in place
Oct 22, 2013 | Lane Furniture Lane Stallion Comfort King...
How can I get the foot rest to close without having to push it back forcefully with my feet?
the model your showing comes with a separate foot stool . you sure you have the same model
Sep 30, 2013 | Fjords 775 Bergen Recliner with Ottoman...
ASHLEY 8050025 Rocker Recliner
Refer this problem to Ashley. It may be necessary to replace parts rather than simply repair your recliner
Aug 21, 2013 | Ashley Furniture ASHLEY 8050025 Rocker...
Recliner foot rest bolt broke and spring came off
looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Mar 22, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
What exactly is a recliner? How is it different from other chairs?
A recliner is a type of chair that can tilt backward. They usually come with a built in foot rest that comes forward when the user tilts back. They have the ability to adjust from a slight incline to lying almost flat.
Aug 09, 2012 | Furniture
2006 V-Rod Forks are LOCKED, the key turns, but
place 1 foot on the handle bars and push
snap the lock because the spring is broken or call a locksmith and have him disassemble the lock and replace the spring
Aug 04, 2009 | Kidkraft Harley Davidson Roaring Rocker
I have a 1998 hyundai excel 1.5litre
If the noise is emanating from under the valve cover, it isn't the timing chain. It can be a stuck lifter and you might want to try a lifter cleaner from an auto parts store. I think you will need to change the oil after adding the cleaner and running the engine for a while. If the engine uses mechanical lifters, the noise could be coming from a bent rocker arm or a worn push rod.
You may be able to narrow down the source of the noise by using a longer screwdriver, placing the tip at various places and resting the handle on the bone behind your ear. Obviously, stay well clear of anything rotating.
Feb 18, 2009 | 1994 Hyundai Excel
Stuck in recline
I know this post is old but I figured somebody w/the same problem might come across this. I had the same problem with my Marathon today. I also own a Roundabout & had no problem changing the recline myself. When my husband came home he took a look & fixed it. All he did was put it in the upright postion , held it in place & turned the seat on it's side & pushed up on the base and it clicked! he pushed on one of the corners (but I don't know if that even matters)
Jan 05, 2008 | Britax Marathon
Furniture Logo
24 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
