Question about Garden
Intek v-twin 23hp riding mower engine runs bad, smells like gas, has a flooded fuel filter and dies when blades are engaged. Anyone know what this issue is?
Posted by Tyler grass on
Carl Rock
  • Garden Master
  • 2,442 Answers
You meant air filter is saturated with fuel?
Yes, then likely the carburetor inlet needle valve is not functioning. Could be stuck valve, bad float, debris in fuel. Remove carburetor bowl for inspection.
Posted on Jul 11, 2020
5 Related Answers
GM Elec
Bruce Bracey
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
Mark Juenemann
  • 3 Answers
SOURCE: When I engage the mower blades, the tractor tries to stall
Besides the reverse switch, the seat switch will also cause this.
Posted on Jul 12, 2009
mickey813
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
Anonymous
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
Anonymous
  • 33 Answers
SOURCE: 46" mtd 25hp riding mower. Idoling ruff...
I had a similar problem on my 42" MTD riding mower, the vent in the gas cap was plugged up. Replaced the gas tank cap and it fixed it (Lowes sells them)
Posted on Dec 30, 2009
Mower died when I engaged the cutting blades. Won't restart.
How long has it been since you used it? Could be a clogged carburator filter or bad gasoline. Gasoline left in lawn mowers and other small engines lose their kick after sitting for a fall and winter season. Try removing the carburator cover and take some fresh gas, just about a little less than 1/8 of a cup and pour it in the carburator and try to start the engine. Once it starts cover the carburator with the palm of your hand and then release it and cover again until the machine stays on after you remove your hand. This is called priming the engine.
Jun 18, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
John Deere L130 riding mower w/23hp Kohler Engine,
need carb rebuilt one problem may need valve job carb rebuild 80.00 valve job 100.00 per cylinder have to take in to shop for this
Sep 14, 2014 | Garden
24hp briggs and stratton intek power loss under load
Exhaust clog, stale gas, clogged fuel filter.
Aug 13, 2014 | Poulan Garden
I have a B&S 22hp Intek v-twin on a craftsman mower. It starts fine, runs great, but after about 10-15 min it starts skipping and will finaly die after another coupl min. As if it was running out of...
Mine did exactly the same thing until I figured out the replacement fuel cap I bought wasn't vented.I put a vented one on and away I went.Also check for a collaping fuel line,and check the screen inside the gas tank,those corrode sometimes.Hope that helps !
May 11, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
My LGT 2554 Husgvarna mower engine tends to die when the mower blades are engaged. When the engine runs with the blades off at low idle it is ok. When you advance the throttle fast to full it loses power...
A common problem on the 21 & 23HP models is bent valve push rods on one cylinder. With this the engine runs and seems fine, albeit a bit quieter, until you put a load on it like engaging the blades which causes it to nearly die. So you may want to eliminate this as a possibility by running the engine with one plug wire removed and then the other. If it runs with one wire on alone, but not with the other wire on alone, then you have a nonworking cylinder even though it is receiving spark. Just a thought.
Jul 30, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Jun 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
