Question about Philips Televison & Video
Pressing power on my LED TV, the Philips logo flashes on the screen but quickly disappears. Connect something W HDMI, there's sound. When I'm the dark and shine a flashlight on it, I see the image.
Posted by Matt Reiner on
    Top Expert:
  • Philips Master
  • 76,407 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
https://electronicshelponline.blogspot.com/
Posted on Jul 11, 2020
5 Related Answers
Anonymous
  • 244 Answers
SOURCE: W4201C no picture only sound
Try to use dvd player to play video to determine where the problems goes wrong either from the video signal of the cable provider or from the TV itself.
Please let me know any update.
Posted on Nov 23, 2007
Anonymous
SOURCE: No Image but power
On another question related to LCD monitors turning on and off within a few seconds, people suggested that aged/burnt out capacitors on the powerboard inside the monitor needed replacing. A relatively easy job for any technician to do.
Posted on Sep 19, 2009
Anonymous
  • 7 Answers
SOURCE: turn on tv, no picture no sound, shined light into screen,nothing
Check your connections and scart leads, take them out and put them in again. It may be a loose lead or maybe a faulty lead, swop them over to see.
Posted on Apr 28, 2010
Paul Bade
  • 1662 Answers
SOURCE: screen flickers and goes dark u can see the image
There are a couple of Cold Cathode Fluorescent Lamp tubes behind the screen. They have probably reached the end of life. (If you had no flickering, I would suspect a failed inverter.)
Replacement requires disassembling the display housing, then removing a screw from the side of the display next to where the fat pink and white wires go in. On most displays, you can then slide the tubes and their reflector out of the display by pulling on the wires. Be very careful - the CCFL tubes are long, skinny, and very fragile, and they contain mercury. Tubes usually come bare, with short wire leads at each end. Soldering the old wires onto the new tubes is a delicate task best reserved for experts. Alternatively, you can buy replacement tubes with wires already attached for an extra $8 each. See this tech support link at LCD Parts for more details.
Posted on Mar 11, 2011
oiram_jay991
SOURCE: timer LED flashing and tv screen not viewing
please help,pioneer xv-htd7 timer flashing...
Posted on Apr 11, 2011
I have a Vizio TV E500i-B1 and the screen is black when powered on. I have sound and able to see images with a flashlight. what do I need to do to fix it?
You have lost your backlights, look at the inverter board if its a LCD or with LED the power supply that supplies the voltage for the lamps
Nov 13, 2017 | Vizio Televison & Video
Sound no picture
inverter board issue.
Feb 22, 2017 | LG Televison & Video
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
I have a vizio 470-a0 that is dark and the back light blinks every 5 seconds
The front LED light that shows whether the TV is on or off will flash so many ... press and hold the power button for 5 seconds upon plugging the TV in. ... The flashing code I got meant the power supply was bad.
Feb 08, 2016 | VIZIO, INC. E470-A0 47" 1080p LED-LCD TV -...
42 Philips tv won't turn on just blue light flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 10, 2015 | Philips 40PFL4706 40 LED-LCD TV - 16:9 -...
Philips led tv 32pfl3008h frozen on logo screen
Sounds like a firmware fault. Contact the authorized service center for Philips in this case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 03, 2014 | Philips Televison & Video
Philips LED 40PFL9704. Switches off before completing the warming up stage.
Sounds like shipping damage---maybe the display panel got damaged.
May 30, 2012 | Philips Televison & Video
PHILIPS 50PF9630A/37
Quick test of the plasma screen itself:
1) Turn on the TV
2) Try to bring up an on screen setup menu using the remote or buttons on the tv.
3) Does the menu appear? If so, the screen itself is ok.
If it doesn't come up you make have an issue with the screen itself. I am not sure it would be possible to set contrast and brightness settings such that the picture would completely disappear, but I suspect you should be seeing something on the screen just from having turned it on.
We also need to know more about what you have connected to the television. HD televisions typically have several inputs on them including HDMI, digital cable, VGA and component. Let's say for example you have PS3 connected via HDMI. You can tell the PS3 to send audio across the HDMI cable as well as video. You also have the option of running separate connections for your audio signal. It is the existence of these options that make it necessary to understand where and how you have things connected, very specifically.
Sep 17, 2008 | Philips 50PF9630A 50 in. Plasma Television
Televison & Video Logo
42 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
