Question about Sharp Televison & Video
Have a SHARP LC-46LE620UT TV with sporadic audio & video black outs / sometimes it is worse than others times eventually goes out completely for a couple of days/comes back and works fine for weeks.
THE BLUE "ON" LIGHT STAYS LIT WITH NO PICTURE OR SOUND.
Posted by Tomas on
    Top Expert:
  • Sharp Master
  • 76,407 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Jul 11, 2020
5 Related Answers
Anonymous
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: TV loses power
hi, this is typical capacitor issues. they are failing to hold there charge load. they will eventually blow and render the tv useless. these are located on the power board. i suggest a repair in the near future.
Posted on Mar 07, 2009
romsky79
rommel dadulla
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
Posted on May 28, 2009
Anonymous
  • 4 Answers
SOURCE: Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Posted on Sep 19, 2009
Anonymous
SOURCE: Sanyo DP46840 purchased less than 1 week ago from
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Posted on Dec 26, 2010
Lc-32SB21U black screen
there is no back light check the inverter or resistor near the inverter
sometimes its open or change of value
Mar 27, 2014 | Sharp LC-32SB21U 32 in. LCD TV
Sharp LC-32SB21U 32 in. LCD TV poor audio
The main board is having issues eventually the sound will drop out altogether. Replacing the main board should solve the issue. You can get the main board from www.tvrepairworld.com
Oct 03, 2012 | Sharp LC-32SB21U 32 in. LCD TV
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Weak audio gets weaker
The ocean sound is 'noise' which means a bad connection. Best thing is to unplug & plug back in all cinch & scart etc cables, while turned off, of course. do this a few times for each cable, then turn it on.
Sometimes it is the headphone jack, have you used it recently?
Try plugging & unplugging the headphones quickly a few times, that normally solves the problem.
If you still have a problem then it's internal and the TV needs looking at.
Apr 22, 2017 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos 32 nch TV, turn TV on, come on & goes off withn 2 sec
You have an intermittent power supply issue. See if you can get a used one on the cheap.
Aug 23, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp TV Audio Problem
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Sep 15, 2008 | Sharp LC-26D6U 26 in. LCD Television
Video goes black on startup
sems like your pisture tube for the tv is going slowly out. replace the tube or replace the tv, its cheaper to replace the tv then a new tv screen colour tube.
Aug 23, 2008 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
42 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
