My similar washing machine gives an OE error. It washes but won't spin giving the OE error. Please help
Posted by Ron Snodgrass on
Fathima Aafrin
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
OE error code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter..... please clean drain hose back side of washing machine.. Thank you
Posted on Jul 12, 2020
Testimonial: "Thank you. It is exactly the problem I found!"
Andrew Taylor
    Top Expert:
  • Washing Mach... Master
  • 33,337 Answers
'similar'???
OE error
code indicates that the washer is unable to drain the water it used during the wash cycle. OE can be triggered by a kinked drain hose or a clogged drain pump filter.Aug 20, 2015
OE Error Code - Front Load Washer ' LG USA Support
VIDEOS
https://www.google.com/search?q=similar+washing+machine+gives+a+OE+error
Posted on Jul 10, 2020
Wont spin keeps coming up with oe on screen what does this mean
LG washing machine error code OE. Error code OE on The LG washing machines simply means the pump is blocked. Presumably the water isn't being emptied properly you might have something blocking the pump.
https://www.youtube.com/watch?v=JBCodfFo6Bc&vl=en
https://www.youtube.com/watch?v=KixjQQdGNF4
https://www.youtube.com/watch?v=A4ENzr2ZR1c
Oct 07, 2018 | Washing Machines
WASHER DISPLAYED "OE" NOW IT WILL NOT DO THE SPIN DRY
Hi there, my mum actually had that problem with her LG washing machine, we did clean out all the drains and hoses just like you did, and also checked the pipes for any damages(cracks/ bends). Turns out the cause was that the machine just wasn't sitting level, so it wasn't draining out properly. Water just collected inside the front of the machine causing that error. Check if the machine is level, and while you're at it check your filter for clogs.
Mar 08, 2014 | Kenmore Washing Machines
My washer wont unlock so I can get my clothes out, and at the end of its cycle it flashes OE...how can i fix it?
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 11, 2011 | Washing Machines
My washing machine is giving me code OE. it is not not spinning. checked the belt and it is fine. any help would be great. thanks kylie
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Washing Machines
Machine doesn't drain & spin, it says "OE" or sometimes some other message "E something"
heatman101
May 23, 2011 | Washing Machines
Dryer does not spin dry, water left in drum...Error code OE
heatman101
May 02, 2011 | LG Dryers
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
