Question about Hardware & Accessories
My Dyson Am07 fan shuts off unexpectedly e.g - when timer is NOT set it shuts off after 1 hour or so - when timer set to -- stops after a couple of hours. - when timer set to 9h shuts off as above
Posted by Njs on
JonSnell Electronic
    Top Expert:
  • 31,846 Answers
Contaminated filters can cause this.
Posted on Jul 10, 2020
5 Related Answers
David Coomer
  • 1073 Answers
SOURCE: Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Posted on Apr 11, 2008
John Miller Jr
  • 148 Answers
SOURCE: Acer 5520 power shutdown
Possible heat issue. Check the cooling fans and see if theyre running. Usually one on the bottom, back or side of the laptop. Make sure that the cooling vents arent blocked during use.
Posted on Apr 04, 2009
Anonymous
  • 4 Answers
SOURCE: how to set fm/1 stuz-l timer instructions
The timer works just like a lamp timer. First set it up on the correct time (white arrow on the inner circle). Next push the 15 minute increments down when you want the heater to run.
Posted on May 09, 2009
Anonymous
SOURCE: After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Posted on May 14, 2009
oms465
MadeletricO
  • 84 Answers
SOURCE: HP m7250n shuts down unexpectedly.
your power supply is faulty you will need to replace it. If you recently installed a new hardware it could be you don't have enough power to, either upgrade you power supply or remove the hardware.
Posted on Feb 27, 2010
Testimonial: "I replaced the power supply this morning at 9:47 am and it is now 10:07 pm. It has run for over 12 hours. Thanks for the info. I suspected it also. "
Tip
How to clean your Dyson Cool fan
How to clean your Dyson Cool AM01 or AM06 desk fan, AM02, AM02 Living, AM02 Mini, AM07, AM07 Living or AM07 Mini tower fan, or AM03 or AM08 pedestal fan.
Your machine may differ to the one shown in the video, but the process for cleaning it will remain the same.
IMPORTANT: Please turn off and unplug your Dyson Cool fan before cleaning it. We recommend using a soft, dry cloth or soft dusting brush to clean the intake holes and loop amplifier. Do not use liquids, polishes or detergents to clean your Dyson Cool fan as this could cause damage not covered under guarantee.
on Nov 27, 2014 | Dyson Dryers
Tip
Dyson Cool AM08 Air Multiplier pedestal fan - Getting started
How to assemble and use your new Dyson Cool AM08 Air Multiplier pedestal fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
on Mar 07, 2014 | Dyson Dryers
Hi just brought Dyson am07 tower fan home from the shop. At first it worked fine but after a few minutes it started to show F3 and does not work
i dont know personally but try this link http://www.dyson.co.uk/support/am07/am07-tower-fan-white-silver best to get help from the experts :)
May 11, 2015 | Dyson AM07 Tower Fan
My dyson fan was serviced last winter by you as it was recalled now it does not work , the lights come on and the motor runs 2 seconds and dies
Hi Kathy, it's Jack at Dyson.
I'm sorry to hear you're concerned about your Dyson fan heater. However, this could be normal behavior from your machine, as the heater would usually display an error code if was an actual fault.
If the target temperature you've selected (shown on the LED display on the front of the machine) is equal to less than the ambient room temperature, the machine may run momentarily until the intelligent thermostat shuts it off.
The solution is to raise the target temperature, using either the remote or the controls on the base of the machine, until the heater runs. It's important to keep in mind that what you're selecting is the temperature you want the heater to heat the room to - so the machine won't run if the room is already at or above the target temperature.
I hope this helps, but if you'd like to discuss this with one of our experts you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 22, 2015 | Dyson AM07 Tower Fan
Tip
Dyson Cool AM07 Air Multiplier tower fan - Getting started
How to assemble and use your new Dyson Cool AM07 Air Multiplier tower fan: adjust the power and oscillation, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
Tip
Dyson Cool AM06 Air Multiplier desk fan - Getting started
How to assemble and use your new Dyson Cool AM06 Air Multiplier desk fan: adjust the power and oscillation, change the angle of the loop, set the sleep timer and store the remote. The sleep timer can be set between 15 minutes and nine hours.
How do I disassemble a Dyson Cool AM07?
Hi Glennis, it's Jack at Dyson.
I've included our Getting Started guide for AM07 below. To disassemble it, you would just need to reverse these steps. To remove the loop amplifier, hold the main body firmly and twist
the loop amplifier anti-clockwise to unlock.This may be a bit stiff if the fan is brand new and hasn't been disassembled before.
I hope this helps, but if you need further guidance from our experts, just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 17, 2014 | Dyson AM07 Tower Fan
Dyson instructions
Hi there, it's Jack at Dyson.
The AM07 Tower fan is quick and easy to assemble - our Getting started video guide shows you how:
I hope this helps, but if you have any additional questions you're welcome to give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 30, 2014 | Dyson AM07 Tower Fan
Need a manual Dyson am07
You should find our video guide helps in getting started with your new AM07:
However, if you would like a .pdf file of the AM07 User guide, please email me directly at [email protected] so I can send this to you.
Jul 19, 2014 | Dyson AM07 Tower Fan
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
