How do I connect my Sinotec 49 uhd smart digital led tv to the internet
Posted by Michael Smith on
KP Legaspi
    Problem Solver:
  • 12 Answers
To Connect to a wireless network use a wireless link stick into one of the USB ports. Once connected, a question, switch to a wireless network will appear, Select YES. And your TV will connect to the network.
If your TV does not recognize your WIFI link stick, you will manually set up a wireless connection. Press MENU button on your TV remote. Now select the SET UP portion on the menu. In the SET UP menu, select NETWORK,make sure the to select on the Network Type is WIRELESS.Then Select NETWORK SET UP, choose select the network. When your wireless network is found, select it from the list. ENTER your PASSWORD. the press the OK/ENTER on the remote. Then your TV will start to connect.
Posted on Jul 10, 2020
5 Related Answers
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: How do I connect my ps3 to the Samsung smart tv
For best performance I recommend you connect a HDMI cable from the PS3 to the HDMI input on your TV.
To display the PS3 you need to select the HDMI input on your TV.
Posted on Mar 11, 2012
SOURCE: Sinotec LCD LED 42 TV does not switch on only have a red blinking light
The set has an internal fault and needs to be serviced
Posted on Oct 03, 2012
Testimonial: "Thanks, Am sending it back as it is only two weeks old"
james ayers
  • 170 Answers
SOURCE: I have Samsung UE55F9000 UHD smart TV bought only two months ago, when switch it on SMART TV screen appears and its shuts off and goes blank completely. Red switch light keeps flickering on and off. A
Check power cord is plugged in all the way.
Posted on May 17, 2014
isaicon
Jerry Ancion
  • 8 Answers
SOURCE: Hiw do i connect my tv to the internet? 8ts a bush 40" full hd led smart tv
You really need to read the manual to your TV. You need to have a router connected to a high speed Internet service. If you mean connect to the Internet, your smart TV will,have to have a browser, like Opera to enable you to get online. The smart TV apps are selectable with your remote, but you have to get the connection first. If you don't have high speed Internet and a wireless router it ain't gonna work. I don't have the manual to your set, so I can't tell you the exact steps you use on your remote control.
Posted on Jan 25, 2015
gopakumarg43
  • 76407 Answers
SOURCE: How can i connect my JVC LT-49KC65 49 Smart tv to the internet IT KEEPS SAYING NO SIGNAL
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
Visit these sites to get more details.
Posted on Jun 01, 2017
The colour on my UHD 55" Smart Aim TV is not right yellow is green I've tried all the settings I even restored the factory settings it still the same the model number is cz1755.Please can someone assist me
If you have restored the TV to its manufacture factory setting and still have the same issues, and also have tried to adjust it manually, more likely your TV is going out soon and needs to repair by the certified electronic repair facility. Because of the brand/model, is really not worth fixing. By the time you invest fixing it, you can by a brand new TV from Walmart a Sharp, JVC and Toshiba 55' for under $300 bucks. In addition, there's no setting you can do or adjust to resolve your TV issues when it comes to LED colors malfunction. If this is a Dixon 55" TV, it an OK brands. Dixon, Sinotec, and Hisense are cheap TV, and I doubt you going to get a good service longevity out of those bands.
Jul 30, 2018 | Televison & Video
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
How do I connect my samsung 2300 Hi Fi audio stereo?
Presumably, you will be wanting to connect audio OUTPUTS from the TV to the audio INPUTS of the receiver.
Jan 19, 2016 | LG 65" Black UHD 4K LED Smart HDTV -...
How do I change my LG 4k to a higher resolution.
You cannot change anything from the tv side. TV automatically select the resolution based on the content you are playing. Play a 4K video the tv will take care of it.
Jan 29, 2015 | LG 65LA9700 65" 3D 1080p LED-LCD TV - 16:9...
I have recently purchased a LG 55"UHD LED LC TV and My mother in law has the same tv and hers is coming up with a recording feature on the tv that mine isn't. I there a problem with the initial setup
Are you referring to the DVR function of the TV, if so what country are you both in? I believe the US does not allow the DVR feature on the US model TV's (or didn't when I worked for LG), Canada does.
Check you both have the same software level, look in the support menu for the software revision.
Jan 04, 2015 | LG 55" Uhd 4k Smart 3d Led Tv - 55ub8500
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
LG smart tv, how to play videos from internet?
Refer its user manual for details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2014 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
