Hello, my 50HUH5500-UA.CUSJLH LG TV has no pic no sound. I have standby 3.4v, the two pins above should be 13.3v but they are 7.08v. What is the problem?
Posted by Scott Macdonald on
    Top Expert:
  • Televison & ... Master
  • 76,416 Answers
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Posted on Jul 09, 2020
5 Related Answers
Tom Chichester
  • 57296 Answers
SOURCE: I have a LG Plasma model 50PG60-UA and it won't
Power supply failure
Posted on Dec 19, 2012
Sp Gupta
  • 727 Answers
SOURCE: Hw to fix lg tv cf 20D70 only standby light no sound no pic
Hi Anonymous,
Recently I have replaced the main board for this fault. Check the inverter circuit if you can.
Good Luck
Posted on Jun 30, 2015
gopakumarg43
  • 76416 Answers
SOURCE: lg 47-lf11-ua tv turns on has sound and half picture stays on a few seconds then shuts off
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Mar 02, 2015
Anonymous
SOURCE: loud pop...LG Model 50PQ30-UA Standby light blinks on/off
this **** dont mother ******* work **** ALL YALL HOES how u like that
Posted on Sep 20, 2010
Anonymous
  • 22 Answers
SOURCE: kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Posted on Mar 31, 2009
How to repair LG LCD TV 47LG70-UA no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 12, 2016 | LG Televison & Video
What caused it to shut down?
Probably abrupt power supply failure
Feb 22, 2016 | LG Televison & Video
LG 42LV5500-UA LED TV turns on, but has no picture or sound
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
Nov 04, 2015 | LG Televison & Video
Loud pop...LG Model 50PQ30-UA Standby light blinks on/off
Jun 13, 2010 | LG DU-50PX10 50 in. Plasma HDTV
42PG20 42 in. HDTV Plasma TV: i have an lg plasma tv - 42pg20 when i turn o...
There are several known issues that can cause that.
The top candidate is the main board, the next is the Y-Main board.
Here's a link for repairing the power supply board of LG 42PG20, which also contains a link to how to test your own board to see if it is good or not:
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
Hope this helps!
May 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Kdf-60xbr950 no pic or sound. standby light flashing
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV tuner problems
what isthe make of the tuner card / model if you can getit also what os are you running
Jul 17, 2008 | Edirol UA-4FX External Sound System
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
