Question about Numark Audio Players & Recorders
Everything can be fixed if there is enough money available but it is unlikely to be economically viable and the money would be better spent on a replacement...
Posted on Nov 28, 2020
SOURCE: Fuse
If the fuse blew again then there is more than likely a problem with one or more of the boards components. First start by unscrewing the power supply and looking on the underside, you may see some burn marks. If you do then it is likely that the component above the burn marks has blown and needs to be replaced. If you do not see any burn marks then the best place to start is with the diodes on the board. If its still not working, e.g. the fuse blew again then it may be that the problem lies elsewhere on the power supply... Good luck.
Posted on Dec 06, 2005
SOURCE: cd players locks up when power switched on
arg... email numark they will give you a uk brach to email - there is a reset facilty that may help you (sorry cant rememeber the buttons it was yonks ago) while it sorted mine 'scratch' is now permanently lit only... they suggested a servide to clear that one prob but got used to cueing the record on that deck in scratch mood which is an art in itself lol
Posted on Oct 03, 2007
SOURCE: Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Posted on Sep 27, 2008
SOURCE: Numark CD MIX 2 is making a ticking sound in the CD Deck
clean the laser lens
Posted on Dec 08, 2009
SOURCE: Skipping cd deck 2 on numark cd mix 1 player.
You're best bet is to replace the stock rubber feet with a true vibration absorbing rubber pad. Audiofiles like myself have discovered that Sorbothane rubber is the best for this application. There is no other material that can even come close to matching it's performance. Get yourself a set of their Sorbothane rubber hemispheres, probably something about a 1" diameter would work best. The best place to get them is Amazon.com.
1.25" Sorbothane Rubber Hemispheres
Posted on May 01, 2010
May 24, 2018 | Pool & Spa
Nov 05, 2014 | Numark NDX-900 Pro DJ Controllers...
Jan 14, 2012 | Video Game Consoles & Games
Nov 18, 2010 | Dell Dimension 3000 PC Desktop
May 13, 2010 | Numark TTX1 Turntable
Dec 08, 2009 | Nu Mark Numark CD-Mix-2 Dual CD...
Oct 20, 2009 | Computers & Internet
May 05, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Jan 25, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Jun 20, 2019 | Numark Audio Players & Recorders
32 people viewed this question
