Question about Bryant Heating & Cooling
Need to replace a bad contactor on a Bryant 661CJ030-A I cannot find one that looks the same and I cannot identify any numbers on the bad contactor. Does anybody know what contactor I need?
Posted by Trevor Andrews on
Mark Bean
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
This model can use a generic contactor providing it is rated for the amp load of the compressor and fan of the unit. I will link a similar contactor that you can use.
https://www.supplyhouse.com/Trane-CTR2573-24V-2-Pole-Contactor-30-AMP
Posted on Nov 27, 2020
I have a Bryant system model 661CJ030-A. Outside unit wont turn on, i replaces the capacitor and still nothing what gives? Im stumped can anyone help?
if you have 240 volts at contactor you either have defective contactor or the 24 volts is not there.to pull contactor in.
2answers
We have a Bryant 556a model, puron Central air saystem. The air handler unit keeps blowing the 5a fuses. I replaced the filter. I cleaned the main contactor at the compressor. It ran for a couple...
The small wires that go from your furnace to the outside unit could be freyed or bare and touching something or maybe even together. Some time dogs will chew these wires outside or under a house if you have a crawl space. You may need to inspect the wires . If looks bad, you can go to a local hardware store and buy new wiring.
I have seen the contactor also blow this fuse. Especially if the contacted are pitted or at time the 24volt coil will be shorted.
These are the two main problems that could be occurring. Good luck. Mark
My a/c unit will not turn on. It is fine at the thermostat and the blower fan turns on but the a/c unit outside will not turn on.
First check the disconnect/circuit breaker that should be located close to the outside unit. Next remove the cover where the power goes into the outside unit so that you can see the contactor. Do a visual check of the contactor and contacts. Set the thermostat to make the A/C come, then look at the contactor to see if the contacts have closed. Use a voltmeter to check for power on the load side of the contactor. If the contacts didn't close, remove the thermostat face and install a jumper between R and Y terminals and see if it pulls in then. If it does then, the problem is your thermostat. If the contacts close and you have power check the capacitor next. If it looks swollen, it is bad - replace it, otherwise you can check it with a multimeter with the capacitor check function. Try these simple checks and let me know what you find if this doesn't fix it so I can give you some more things to look at.
1helpful
Do bryant condensing units have a reset button? We can't get the unit to kick on. All power is correct and fan starts inside, but can't get condensing unit to kick on.
Most Bryant units do not have a reset button but could have a low pressure or high pressure switch for a safety to protect the compressor. Verify power from the thermostat to the contactor by following the thermostat wires all the way to contactor inside of electrical compartment... TURN POWER OFF BEFORE OPENING.... If power is to contactor and contactor is pulled in then you would need to look at the capacitor of which is a canister about 6 inshes tall with wire terminals on top.. this part should be flat on the top and if it is rounded then thats your problem.. if not then contact a local company to troubleshoot and make necessary repairs.
I have a Bryant 661CJ030-E. While in cooling mode
Refrigerants are regulated by the EPA. In order to purchase it, you need an EPA License. If you are low on refrigerant, the leak needs to be found and repaired. This requires special tools.
Additionally, with the information given, it could be an electrical problem. Is the outside fan running, is the compressor running? Your best bet is to call a professional.
Air conditioner is only 2 years old. Outdoor fan is not working. Air is circulating inside house but not cool. Bryant Legacy line Model No. 123R Help - seems too soon for the compressor to go bad. What...
You said the outdoor fan is not running, can you hear the compressor running? If you can hear the compressor running then start by checking the fan capacitor. If you can't hear the compressor, then check the breakers or fuses or disconnect. One of these should be located near the outside unit. If you look at the contactor you can see the contacts. When the unit is off they should not be touching, when it is on then the moveable contacts should be pulled down and touching the stationary contacts. You can get some on at the thermostat while you watch the contactor to see if it moves when they change the thermostat to call for a/c. Let me know what you find and I can give you more advice.
I have a bryant AC/heat pump unit. Today I noticed that the air coming from the vents is just warm air, so i went out and the unit in not running condencer nor the fan. (it is the 661cj030-e unit).the only...
YES. It seems your capacitor is bad.
It must be replaced with the exact specifications as the original.
IE: MFD and VOLTAGE for the compressor and fan motor.
Example...35+5 370 vac.
1helpful
Is the Bryant 661CJ030-A heat pump single- or multi-stage?
Single stage heat pump. But you must have a two stage tstat for backup electric heat. You single stage cool two stage heat. The second stage brings on the electric heat in case the heat pump can not keep up. Wiring goes r y w1 on most heat pump tstats are switchover valve or o terminal. W2 second stage heat or emergency heat. g is fan c is common terminal.Rus
1helpful
2answers
Have a Bryant AC/Heat pump. Model# 661CJ030-A. Problem: Air conditioner not cooling,fan comes on,there is a click and a hum but compressor doesn't come on to cool. Does thermostat have anything to do with...
Found charge capacitor top ballooned replaced with a universal capacitor found at a local appliance repair shop system works like a champ capacitor is located behind the interior electrical panel after removing the side panel
Heating & Cooling Logo
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
john h
Tom Chichester
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
