My proscar 32 inch tv wont power on red light is on
Posted by Jamarei Carson on
Tom Chichester
    Top Expert:
  • Televison & ... Master
  • 57,296 Answers
Open fuse or failure of a power supply component
Posted on Jul 09, 2020
5 Related Answers
Anonymous
SOURCE: TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Posted on Apr 16, 2009
Anonymous
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
vinhson65
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
Loaded4th
Kenneth
  • 97 Answers
SOURCE: 32 inch samsung red light stays flashing tv does
The power supply in many of Samsung’s TV's have capacitors installed that are rated for 10v that feed a 12v bus causing them to bulge or fail. If you are out of warranty, get someone who understands electronics to fix it.
Posted on Mar 13, 2010
SOURCE: my 32 inch dynex tv wont turn on its only ablout 3
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 09, 2011
Tv wont turn on
It sounds like a main digital board fault. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
I have a Polaroid flat screen TV 32 inch lcd W Red Light Plz HELP
blown cap in the power supply it will be domed on the top where it vented
Sep 16, 2009 | Televison & Video
Ilo 32 inch LCD tv will not turn on
replace bad cap in the power supply the top will be put up
Aug 28, 2009 | iLO 3200 32 in. LCD Television
Ilo 32 inch LCD wont turn on
power supply bad inside of tv
Aug 28, 2009 | iLO 2600 Television
Wont turn on
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
Tv won't come on
check the relay drive transistor
you need a qualified tv repair personal to check tv
Jan 15, 2009 | JVC AV-32D305 32" TV
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
32 inch sony wega
power board problem, needs to be repaired or replaced. Any TV tech can do this with the proper replacement parts. Common.
Mar 03, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
