Model:L22H998 /22 LCD no signal?! Direct TV - Televison & Video
Posted by Annwaddell on
ray gallant
    Top Expert:
  • Televison & ... Master
  • 69,326 Answers
TRY CHANGING THE INPUT SOURCE
Posted on Jul 08, 2020
1 Related Answer
marionbagget
  • 718 Answers
SOURCE: my philips lcd digital tv says I am recieveing
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
Posted on Mar 16, 2009
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
When I turn on the tv, I get the Direct tv signal
It ur Direct tv converter box,unplug and replug or turn power switch off/on again so the box can reboot get a new and updated informations.It well back in the air if not must call the direct tv customer service for the disk check,it not ur tv.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
I recently changed from Cable to Direct Tv now when I change channels the screen goes blank for 15-30 seconds before the actual show begins. the picture is fine but there is a delay when changing channels
When you switched from cable to Direct TV you went from a direct connection to having a box in the middle. The box is required to to decode the signal. There is nothing wrong with the tv, you just may not have the best signal.
Jul 06, 2009 | Vizio VO47L 47 in. LCD TV
My philips lcd digital tv says I am recieveing analog signals from a digital direct tv sat. How do I get my tv to change to accept digital signals?
Mar 16, 2009 | Philips 32PFL5332D 32 in. LCD Television
I cant figure out how to plug in the direct tv cable
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Mar 07, 2009 | Akai LCT4216 42 in. LCD Television
N2750W PROBLEMS WITH DIRECT TV
just press the "PIP" button on the remote it happened to me and i just thought that it looked familiar and i pressed it and it worked hope it helps :)
Nov 19, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Olevia 32"lcd
All I did was switch out televisions and found that the DirecTV receiver was the problem.
Sep 13, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
