1E78-151 reset button location - Computers & Internet
Posted by Judy Jayne on
  • Larry Ng
    Larry Ng Jul 08, 2020
    judy what Comnputer is this, what is wrong.
    PCs long ago got rid of the nasty reset button.
    gone they are now.
    why not tell what is wrong first then ask for help, we can not guess
    who made your PC
    you posted to computers for help computers
    but non stated, google tells me it is thermostat, is it?
    this
    White-Rodgers 1E78-151 Series 70 Digital Thermostat H/C
    is this your NON computer.=?
    YES?
    there is reset,
    you take the batteries out for say 15mins
    and it is reset.
    the manual on this is just 2 pages long.
    google finds it 1st hit,.
Ngoro
    Top Expert:
  • Computers & ... Master
  • 2,640 Answers
Where is the reset button ?
There is no reset button for the fuel pump if that is your question.
Aug 26, 2014 | 1991 Toyota Cressida
How can I reset my Polaroid Tablet?
In the event that the tablet freezes or does not function properly, press the RESET button located on the bottom panel.
Follow the link to see the diagram of where to find the switch, it is in the bottom left corner of this web page. Zoom to maximum (200%) to clearly display the picture showing the location of the reset button.
The button is tiny, you will need to use a paper clip or the tip of a stylus to press the RESET button.
Data stored on the tablet will not be affected by using the RESET button.
The location of the reset button is the same on all models.
http://www.polaroidstore.com/store/images/pdf/pmid1000-polaroid-wifi-internet-tablet-with-touch-screen.pdf
May 24, 2014 | Polaroid 4.3" Internet Tablet
Were is reset located inside rcag35831at
The reset button is used to return the unit to its factory settings.
Step1: Turn on your vehicle, but do not start the engine.
Step2: The reset button is located on the right hand side of the deck. Just to the right is the reset button. It is a circular shaped button the size of a pencil lead thickness and it is not labeled. If you have trouble locating the button, use the flashlight to help illuminate the area.
Step 3: Depress this button. If you have do not have smaller fingers, you may need to use a pencil or pen to depress the reset button.
Regards
BEADHZ
Mar 18, 2013 | RCA G35831AT 35" TV
What if I can't remember the name and pass word I gave it
Please see below.
Hope this helps!
Regards,
Reseting the router to the factory defaults will delete any changes you have made to the router, including any security settings. This should be used as a last resort.
Reset Button dir-628-300x300-256x256.jpg The steps involved in reseting the router is simply pressing a button located on the router. The image below (courtesy of D-Link) shows where the button is located.
D-Link DIR-628 Reset Button Location
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot. Wait about 30 seconds before logging into your router.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
Apr 18, 2011 | D-Link DIR-615 Wireless Router
Where is reset button located
The reset button is located on the bottom of the disposal. It is a small red button that you just push in to reset. Thank you
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do i reset
The first method involves using the reset button that is located at the back of the router. It isn’t hard to reset the router this way, but does require physically being in the same location as the router.
To reset the router using the reset button, use these steps:
  1. Look for the red reset button at the back of the router.
  2. Press and hold the reset button for approximately 5 seconds.
Aug 31, 2010 | Linksys WRT160N Wireless Router
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside (very small)
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
  1. Lift the antenna
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
Resetting frozen tomtom910
The reset button is located on the backside to the right of the connector. Use a straightened paper clip to press in the reset button. the button is difficult to see but it you look into the area where the window mount is and actually just to the right of the copper connector and a little higher that's where the button is located. Good luck
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Computers & Internet Logo
23 people viewed this question
Ekse
Marvin
Marvin
