Question about Kenmore Kitchen Ranges
Needs a new igniter no biggy really.
Posted on Nov 16, 2020
Sorry but we do not advise self fixing of gas appliances they go BOOM and can burn your house down if not done properly
SOURCE: Oven burner doesn't light
Replaced the ignitor on mine 10 mins ago.... Works like it's brand new. You have to remove the bake pan in the bottom of the stove, remove the drawer, and the sheet metal shield protection the connection. Entire job was 10 mins.
Posted on Oct 22, 2008
SOURCE: GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Posted on Mar 02, 2009
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
SOURCE: Kenmore Oven Problem
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Posted on Jul 29, 2009
SOURCE: Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Posted on Aug 22, 2009
Dec 13, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 19, 2011 | Kenmore 95032 / 95034 Electric Kitchen...
Jan 11, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Dec 15, 2010 | Kenmore Ovens
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Jul 06, 2008 | Kenmore Kitchen Ranges
Mar 26, 2008 | Kitchen Ranges
29 people viewed this question
