Question about GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel
Need instructions on my GE profile wall oven
Need instructions on my GE profile wall oven model # jk915bof288
on how to operate the oven controls
Posted by jcorbett4 on
Anonymous
  • 69 Answers
GE.COM really helps
Posted on Sep 20, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
    When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
    Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
    I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
    Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
    Dec 20, 2017 | GE Profile JT965 Electric Double Oven
    GE profile wall, single, Get a
    Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
    Thanks
    Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
    Ge Profile built-in 27 inch wall oven -- When I
    f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
    Jun 18, 2009 | GE Profile JT912 Electric Single Oven
    F7 Failure Code
    Hi markw421,
    No you do not need to pull the entire oven. If I knew the model number I could give you specific instructions. You can go to www.partselect.com and put in your model number and you will find diagrams that will help you open up the beast.
    Regards,
    Powerman
    Oct 30, 2008 | GE Profile JTP18 Electric Single Oven
    GE Profile 30" Built-In Single Electric Convection Wall Oven - Stainless-Steel Logo
    796 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Michael Thomas
    Michael Thomas
    Ekse
    Are you a GE Oven Expert? Answer questions, earn points and help others
