Dwf 7108 on power error code L1 - Office Equipment & Supplies
Posted by Muhamad Faizal on
Don A
  • Office Equip... Master
  • 2,756 Answers
Have you tried a Google search or Duckduckgo search for Dwf 7108? If so, you likely have discovered the device can not be found without other identifying information. If I assume it is a printer and not an office washing machine from DaeWoo, I find myself routed to AutoDesk forums. The point is, you need to identify the Brand and Model and type of hardware you are enquiring about, as well as error codes (which are typically specific to brand). Sorry. You might do a Google search for the brand named object and model number plus error codes or go to the manufacturer's site for support. I can't identify the hardware you are referring to.
Posted on Jul 07, 2020
1 Related Answer
Rahim
SOURCE: daewoo washing machines dwf 7108 error e4
my deewoo 7kg showing E4 when power was switch on.
Posted on Dec 19, 2012
What does error code 3 mean on akita dwf 089 mean ?
What does code error 3 means on akita washing model dwf -089
Sep 29, 2016 | Washing Machines
What is error code f69 on a frigidaire electric range
Hello. You have a serious problem--that error code means L1 or L2(the 120v supply wires) may be shorted with the neutral on the incoming power supply. TURN OFF THE POWER!! Check the wiring at the terminal block. The neutral is the center post. L1 is usually black and L2 is usually red. The F68 and/or F69 error means high voltage or the above-mentioned condition. Once you have verified there is no incorrect polarity or voltage condition, then the main oven control board must be replaced. The part number you might need is 316562011. I hope I helped you!
Sep 20, 2015 | Frigidaire Kitchen Ranges
Daewoo washing machines dwf 7108 error e4
Oct 19, 2012 | Washing Machines
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
Error code on the display
dear sir,L1 code is for scan unit.if scan cannot move ,this problem occures.
Jun 14, 2010 | Sharp Office Equipment & Supplies
I have a DAEWOO DWF-1150P top loader washing machine and when I switch it on I get an error code E9. Can you please tell me the fault and how to repair it?
I have a daewoo top loader washing machine ,,
Mode W/M-DWF-200MP
The power main board does not take the programs to work how should be its olny one program
Apr 29, 2010 | Daewoo Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Jun 16, 2009 | Washing Machines
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
Marvin
Marvin
