Question about Mitsubishi Heating & Cooling
Have reset the wall unit via the remote, have washed the filters, powered the unit off and on, all with same result. I only have access to the wall mount unit inside my apartment.
Check the code to see what that one means.
The codes are on the inside of the indoor unit cover. See this link to find them.
https://www.visionair.com.sg/blogs/news/what-does-it-mean-mitsubishi-electric-starmex-blinking-lights
Posted on Nov 27, 2020
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
SOURCE: No heat generated from the inside unit in Misubishi Mr. Slim
If you do not have a windbaffle installed on the outside unit the unit may never come out of defrost in low ambient temperatures. Depending on the outside temperature it might be telling the pcb to stay in defrost to keep the compressor from slugging and being damaged.
Posted on Jan 20, 2010
SOURCE: i have 2 Mitsubishi electric "Mr Slim" type
Have your system checked by a professional.
From what you are describing here it seems as thoug you have a slight leak in the system somewhere and therefore the system is not cooling or heating properly.
Have them check the system... verify the low charge, fine the leak and repair it.
Vacuum and recharge the system...
Then check the operation before you let them out of your sight.
...It can be tough to get some contrators back if you let them go before you check it...espec. if you pay them...:-)
heatman101
Posted on Nov 19, 2010
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
Jul 21, 2014 | Mitsubishi Heating & Cooling
May 03, 2017 | Heating & Cooling
Jul 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Mar 07, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Dec 07, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 03, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Feb 18, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
67 people viewed this question
