Question about Garden
Rebuilt carbs on XLT800 waverunner. Now I need to use the choke to get it up to speed. How did I go wrong and what do I need to adjust/Fix?
Posted by JEROME UPTMOR on
Carl Rock
  • Garden Master
  • 2,438 Answers
Https://www.manualslib.com/manual/1058844/Yamaha-Waverunner-Xlt800.html
I only saw initial settings for air fuel. Be careful to not run it lean or you'll burn a piston.
Posted on Jul 06, 2020
JonSnell Electronic
    Top Expert:
  • Garden Master
  • 31,750 Answers
Adjust the main jet/s for the correct fuel mix.
My ryobi weed wasp starts on full choke bu cuts
Yes, you have a fuel issue. Start with adjusting the low and high setting to one turn out each, then set the idle. Could also be need carb rebuilt, air filter, etc.
Sep 14, 2014 | Garden
I have 96 760 yamaha waverunner I rebuilt the
water in your gas or air cleaner is getting wet somhow
Sep 01, 2014 | Motorcycles
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
Choke not operating properly
the carb either needs adjustment or rebuilt most likely
Dec 05, 2013 | Yamaha 2005 Big Bear 400 4x4
Echo LT-200P Weed-eater Carborator problem
1. Carb is dirty and should be cleaned correctly
2. low speed/high speed carb screws incorrectly adjusted
3. incorrectly put together or rebuilt
Jan 21, 2013 | Garden
I have a Briggs & Stratton 2 cylinder motor Model # 42A707-125201. Runs fine at high speed with the choke off, but it will not idle smoothly unless the choke is partially on (about 2/3). I rebuilt...
The fact the choke must be 2/3 applied to obtain a smooth idle indicates not enough fuel is being supplied by the carb at idle speed. Applying the choke richens the air/fuel ratio.
I suggest you revisit the carb idle air/fuel jets, air passages and any adjustments as well as checking for intake air leaks.
Sep 15, 2017 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Ryobi backpack blower will run all day with choke up but as soon as I pull the trigger it starts bogging down
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Dec 12, 2009 | Ryobi Backpack Blower 25.4cc
Engine idles excesivly high after carb was rebuilt.
You need a new choke pull off. They are around $30 dollars.
Dec 09, 2009 | Ford F-250 Cars & Trucks
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
